how to clean 1966 side trim?
alright the trim on the side of my '66 is really crappy looking and faded, i was wondering if there was any way of cleaning it up nice again, but i don't know if its stainless or aluminum trim?
![]() even the trim on the side of the cab is crappy looking. |
Re: how to clean 1966 side trim?
WOW, that is a nice truck, might have to steal your color combo.
Wenol metal polish in the blue tube will clean it up without stripping the anodizing. After that you can wax it to protect it. Though its temporary, aerosol Pledge furniture polish will "wet" the anodizing if its chalky/dry and bring out the depth and shine and will make the wax last longer. Porsche recommended using petroleum jelly on their anodized Fuchs wheels to protect them from fading.
Here's mine, before and after. ![]() Posted via Mobile Device
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
Unless you want it shiny you could hit it with a scuff pad and make it look like brushed aluminum.
66 shorty ![]() |
ive heard that toothpolish will bring the shine back. I suggest using the wifes tooth brush on a test section. to make sure you dont dammage the trim.- Cheers -Nate
66 c-10 swb stepside -my daily driver 74 1Ton CrewCab Shortbed 4X4 (2) 91 2500 suburban 4X4 91 K5 Blazer 4X4-wifes daily driver 73 K5 Blazer 4x4- project soon to be 2wd 50 3 window 3100 |
![]() Join Date: Aug 2010
Not that I would doubt theastronaut's experience, but I personally have never had good, lasting results trying to bring back the brilliance on anodized parts that have already gone milky. I have had fantastic results however by stripping the anodizing off and polishing the raw aluminum. Doing it that way means you'll have an ideal time to clean up all the little dings too. That said, straightening and polishing trim is NOT for the impatient enthusiast. It's most definitely an exercise in finesse.
![]() Join Date: Mar 2005
Very true. The factory side trim is so thin that if you apply just a little too much pressure on the polish wheel, it'll either kink the part or shoot it across the shop like a missile. Slow and easy is the way to go, with just enough pressure on the wheel to build heat but not too much where it wants to grab. The bedside trim is especially fun because it's so long. I tape them to a 2x4 and hand-work them with a buffer.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
