What type of block
Is there any way to find out if I have 2 or 4 bolt main, wihtout taking the oil pan off?
1970 k10 1971 C10 Gilbert Az |
usually the only sure fire dead on way is to pull the pan and look
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
get the block # and go to http://www.mortec.com/castnum.htm
1972 GMC SWB, 305 powered 1980 diesel VW pickup, Needs a Heart Transplant 1997 Toyota Taco The Second Amendment is in place incase they ignore the others. |
but even still some casting numbers could be either 2 or 4 bolt the only sure fire way is to pull the pan. if the engine is running good or in a truck it doesnt matter much anyways a 2 bolt is plenty strong for about any street bound motor. and in some cases the 2 bolt is stronger than the 4 bolt
Junior Member
I think if the last 4 numbers are 0010, it`s a four bolt.
71 C10 Step Daily Driver 72 K10 Suburban Work in Progress www.louisianaclassictruckclub.com |
My spare 350 is 0010 and its a 2 bolt, but you can get a 2 bolt Splayed at the machine shop and its supposedly stronger than a 4 bolt.
1971 LWB Chevy C-10 350/350 3:42 eaton ![]() |
Fabricate till you "puke"
3970010 is a very common block, and can be 2 or 4 bolt.....the 1 in my Longhorn is a 2 bolt block(also 10/20 high nickel). i also have 2 spare blocks with the same casting # , & they are also 2 bolt blocks. the best way to know for sure, is pull the pan ,as cableguy suggested
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Ive owned 4 0010 blocks...all were 2 bolts
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
i will let you guys know how much a bolt will handle when i get the brodix track 1's and switch to a roller cam setup
Junior Member
Guess I got lucky, my 0010 is a 4 bolt. I was told that 0010`s were all 4 bolts, wan`t sure that`s why I said "I think".
yea..I think im just unlucky with the 0010 blocks..I heard over half have 4 bolts
Junior Member
I guess cableguy is right, the only sure way to tell is remove the oil pan.
yea jim i have had 3 010 block that are 2 bolt and in the machine shop i work in have seen who knows how many that are also 2 bolt so im thinking its less than half that are 4 bolts
