What kind of pulley is this?
I have never seen a crank pulley like I have on my truck. Can anyone tell me if this is stock or what??? Any help appreciated.
I am planning to put A/C on the truck (still deciding which kit to use).
Larry 1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green" 1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red" 1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon" 2005 VW Beetle Diesel 44+ MPG "Silver Bullet" |
What?
Re: What kind of pulley is this?
It's actually a two piece unit.
The one closest to the engine is stamped steel, and it's just a single groove model. The one closest to the radiator is of cast iron, and from my experience has been added for AC or other stuff. I have one just like it, but I have the two groove stamped steel pulley.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
Wow Vectorit....that was FAST! Thanks for the info. I'm guessing, based on your response that if I got a two groove stamped pulley to replace the single, I could then use the middle groove for an A/C compressor and then I could still use the bolt on inner groove for my PS pump.
gets board easy.......
man, im not good with the short water pump stuff
![]() Join Date: Mar 2003
I've got the same pulley on my 68 GMC with the 396. Aftermarket AC.
Between Trucks...
I have that pulley on my factory AC truck with a 350 and PS. My water pump pulley has 3 grooves though.
Beat it to fit, Paint it to match... ![]() |
![]() Join Date: Oct 2009
I had the same set up, and when I put in AC I replaced the single groove pulley with a two groove, and put back the other two groove that I already had, so I had four grooves.
One closest to the block is alternator, then AC, then unused, and then PS
1971 C10 Longbed, 350/TH350 |
Thanks everyone. You have all answered my question......again.....this board is a great resource.
I have a 71 c20 and the stamped crank pulley is bent does anyone no where I can buy one from
Posted via Mobile Device |
Wow...this is an OLD thread....
That said, try board member Teeitup....Randy has a large inventory of parts for these trucks...great guy too.
how do I go about contacting him
You can send him a private message...member name Teeitup....or you can search the parts forum for one of his parts threads...
ok thx sir
Are you looking for the single groove stamped pulley? I have one that I took off my engine.
#15 |
Old threads have a lot of good info in them. I like seeing them resurrected now and again.
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 |
