Old 12-19-2012, 03:23 PM   #1
shawno72
C/10 junkie
shawno72's Avatar
Question for y'all
I just swapped out my CPP 5" rear drop springs for some ECE 6" rear drop springs and the stance don't look no different. What do y'all think? I have the actual measurements at home of the truck with the 5" springs still installed. I will measure tonight with the truck in the same spot and with the same tape to be sure the measurements are acurate. I am a little dissapointed with the results so far with the naked eye.
5" spring
Name:  5 spring.jpg
6" spring
Name:  6 spring.jpg
Before
Name:  5 drop .jpg
After
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 12-19-2012, 03:56 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: Question for y'all
Thanks for posting this Shawno. You have proven what I have suspected for a long time. No need to waste my money now. I've always wondered why only 1 vendor carried 6" springs...now I know, lol.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 12-19-2012, 04:17 PM   #3
shawno72
C/10 junkie
shawno72's Avatar
Stupid me wrote the original measurements on the garage wall so from what I can remember I think I am only netting about a 1/4" extra drop.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 12-19-2012, 04:36 PM   #4
chevjayfsd
Project 7dos
chevjayfsd's Avatar
Do you already have blocks or just a spring drop in the back? You could just cut a little off.
7DOS - 1972 C-10
350/350
Porterbuilt/Accuair
20x8.5/20x10
Ride Low or Die
PSSST - Yes it's bagged.
7dos build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=610290
chevjayfsd is offline   Reply With Quote
Old 12-19-2012, 04:44 PM   #5
shawno72
C/10 junkie
shawno72's Avatar
Yeah I have 1 7/8" worth of blocks. My frustration is that I wanted an additional 1" of drop so I bought a 6" drop spring to gain just that. The only problem is after installing the 6" drop spring the truck only looks about 1/4" lower. Either the CPP 5" drop springs actually drop your truck 6" or the ECE 6" drop springs only drop your truck 5".
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 12-19-2012, 07:45 PM   #6
tubbedII
needs more $$$
tubbedII's Avatar
Don't forget that most springs take a little time to settle as well. Don't know if they'll settle another 3/4" though but maybe a little bit more...
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 12-19-2012, 07:49 PM   #7
shawno72
C/10 junkie
shawno72's Avatar
They were used to begin with so they probably won't settle much.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 12-19-2012, 09:52 PM   #8
shawno72
C/10 junkie
shawno72's Avatar
Ok he verdict is in and I am not happy. After installing ECEs 6" drop springs it raised my truck by 1/16". Boo on ECE for their misrepresentation of a 6" drop spring. Buyers beware.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 12-19-2012, 11:27 PM   #9
fastcam1
Young gun
fastcam1's Avatar
load up the bed with a bunch of weight and hope they settle more
67 SWB Custom "JANE"
http://67-72chevytrucks.com/vboard/s...d.php?t=554024
Northwest C10's
http://www.facebook.com/#!/groups/Norhtwestc10s/
Cameron sparks
fastcam1 is offline   Reply With Quote
Old 12-19-2012, 11:30 PM   #10
shawno72
C/10 junkie
shawno72's Avatar
Well it just goes to show that unsprung heights don't mean a whole lot.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 12-19-2012, 11:47 PM   #11
lolife99
67-72 parts collector,…
lolife99's Avatar
Nope,... never did.
So which spring is wrong?
And compared to what?
Only a side by side comparison to a new stock height spring?
Maybe.
Keith
Convert to disc brakes.
Old 12-19-2012, 11:51 PM   #12
lolife99
lolife99's Avatar
For what its' worth,... my ECE 6" rear springs are lower now, than when I first installed them.
Right off the jack stands I didn't think it was low enough.
Keith
Old 12-20-2012, 01:01 AM   #13
jwalk
What was I thinking?
jwalk's Avatar
Sorry to hear that the ECE springs didn't bring it down like you was hoping for. I just got through putting a ECE 4.5/6 on my long bed 68 and ended up adding a one inch block to bring it down a little more. This is with the block and right off the jack stands.
Justin
'68 C/10 Custom Long wide bed
'78 GMC Sierra short wide
Project: Second time around...'68 short wide
http://67-72chevytrucks.com/vboard/s...d.php?t=423949
jwalk is offline   Reply With Quote
Old 12-20-2012, 01:22 AM   #14
shawno72
C/10 junkie
shawno72's Avatar
Well for one these springs were slightly used so I figured they would be pre sagged Bascially the height comparisons were between the CPP 5" and ECE 6" drop springs. I went from the 5" spring to the 6" spring and it raised my truck 1/16". Just using common math I figured I would of lowered the rear 1" by using a 1" shorter spring. Hopefully the rear will settle some more.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 12-20-2012, 03:24 AM   #15
bk2life
maybe someone had the wrong spring in the first place?
i can sell you a 7inch spring 'wink wink'
bk2life is offline   Reply With Quote
Old 12-20-2012, 03:57 AM   #16
leddzepp
Moderator
leddzepp's Avatar
I have CPP 5" rear drop springs. After getting tired of my rear end slapping my frame (there was 1" of suspension travel between my axle and frame), I installed a c- notch. Ece claims that you do not need a notch with their 4/6 drop kit...I find that hard to believe in reality if it is indeed a 6" drop. I am not knocking them on basis of quality and customer service...they are a top notch outfit in every way, and have zero complaints whereas cpp cannot say the same in the least. This is something that has always puzzled me since I rebuilt my suspension.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 12-20-2012, 08:26 AM   #17
shawno72
C/10 junkie
shawno72's Avatar
One other note is that rear end is noticeably stiffer. Not to where the ride is uncomfortable but it definately has a more sporty feel to it. To me, and I wish I had measured, the coils seems a tad thicker on the ECE spring so maybe I'll have a little more load capacity? I did consider the fact that maybe I was sold a 5" spring but I trust the guy I bought them from knew what he had.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 12-20-2012, 10:29 AM   #18
midniteblues
midniteblues's Avatar
not that its make a hole lotta differnce but, I curious how much weight differnce there is between a lwb to a swb and if it affects how much the springs drop.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 12-20-2012, 10:48 AM   #19
shawno72
C/10 junkie
shawno72's Avatar
I'm sure any added weight will drop the rear that much more. I'm gonna ride it out for a few months and see if they settle a bit.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 12-20-2012, 11:05 AM   #20
CC69Rat
CC69Rat's Avatar
One other note is that rear end is noticeably stiffer.. Posted via Mobile Device
Difference in spring rate bubba.. It's just the manufacturer and how they are made and stuff ..
Btw -- Hotchkis sells a 6" spring. They maybe be shorter but if the rate is tighter one vs. the other then your net drop will be different. Example, I have those Jeep springs. 12.75" tall unsprung but they net about a 4" drop.. but they are very very soft. .. Wouldn't that mean the should be 1" taller than your 5" original springs, if unsprung height made a difference?
See what I mean? .. just tryin to help. Not callin you out.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 12-20-2012, 01:21 PM   #21
big_al_71
big_al_71's Avatar
here is a side by side picture of my old five inch springs and the ones from Ece 6 inch drop. The six inch were definetly shorter and they in fact lowered my truck more when i installed them.
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 12-20-2012, 01:29 PM   #22
shawno72
C/10 junkie
shawno72's Avatar
Wonder why mine didn't? The springs were definately differant lengths.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 12-20-2012, 01:39 PM   #23
lolife99
lolife99's Avatar
Different brand.
Different spring rate.
Keith
Old 12-20-2012, 01:41 PM   #24
shawno72
C/10 junkie
shawno72's Avatar
Different brand.
Yeah for sure. Watch after a month of driving they will prob sag down to where the rear is lower than the front.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 12-20-2012, 01:50 PM   #25
lolife99
lolife99's Avatar
I guess the worse part is the unknown.
You KNOW you had 5" CPP springs.
One of the smart things CPP does is put a part number on each spring.
The unknown is that you bought used springs.
Not really sure what you bought or no way to verify it.
No previous meaurement at stock height, that really means anything,... because your old original springs were probably sagging anyway.
The thing is,... you are probably at the lowest stactic drop you can achieve.
Really,... I wouldn't run more than a 1.5" lowering block, with 15" wheels.
(scrubline issues)
When I lowered my '69,... I did the opposite of what I tell people.
I never took any "before" measurements.
Why?
Because I knew I was adding spindles and 3" springs up front.
And 6" drop coils and 1.5" drop blocks in the rear.
I didn't care how much it actually dropped, because I knew this was the lowest I could go with a static drop.
If I go lower,... it will be with bags.
Keith
