Old 12-20-2012, 12:54 PM   #1
bcnya2
bcnya2's Avatar
red interior on a 72
I amm looking to find/red door panels fir a 72 cheyenne.......Im bearing they were never made, and I will need to dye mine? Is that true? I have nev er had much luck dying panels....tbey always sem to chip or scratch and leave the previous panel color exposed. I have also heard tbe reproduction panels are low quality. Does anyone have a super nice-super clean pair of red cheyenne panels? Thanks, Greg
bcnya2 is offline   Reply With Quote
Old 12-20-2012, 12:57 PM   #2
ls1nova71
ls1nova71's Avatar
Re: red interior on a 72
I think the made them in red, but for some reason I want to say only on big trucks, like 2 tons. Someone else will know for sure.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 12-20-2012, 04:13 PM   #3
TBONE1964
Cluster King
TBONE1964's Avatar
http://www.lmctruck.com/features/cb/cbc92.htm
Not sure if this is the correct color red you need. i think they are a little pricey and I would make sure they have a good return policy. I have heard mixed reviews about the quality of LMC parts.
Good Luck
TBONE1964 is offline   Reply With Quote
Old 12-20-2012, 04:14 PM   #4
TBONE1964
Cluster King
TBONE1964's Avatar
Scratch that, after I posted above I went back and read that they are painted. You can do that yourself.
Old 12-20-2012, 05:40 PM   #5
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
They did make them. I found a set in a c/60 ex coca cola truck. They are out there. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 12-20-2012, 09:15 PM   #6
DonsCST
DonsCST's Avatar
My Eckler's Classic Chevy Trucks catalog shows some that you have to specify color, Check the web sight www.EcklersTrucks.com Good luck.
DonsCST is offline   Reply With Quote
Old 12-21-2012, 03:29 AM   #7
nra4life
The red door panels I have in my '72 came out of a big truck, too. I found them at a swap meet in Springfield, Mo. They are orangish, like the red paint in '72.
nra4life is offline   Reply With Quote
Old 12-21-2012, 09:06 AM   #8
bcnya2
bcnya2's Avatar
Thanks for the reply........since they were in a 60series....I am assuming they were not Cheyenne panels with the wood trim?
Thanks,
Greg
Old 12-21-2012, 11:42 AM   #9
sameyrasmea72
sameyrasmea72's Avatar
Thanks,
Greg
I think you could find them in the deluxe pattern ( with the scroll and SS trim ring). Then you could add the WG panels. If you find the base door pannels you can add the trim ring and the woodgrain.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 12-21-2012, 11:16 PM   #10
bcnya2
bcnya2's Avatar
Thank you for the reply. Im trying to keep my original black panels and find red panels....taalll order. If you hear or see a set, please keep me in mind. Have a nice christmas......Greg
Old 12-21-2012, 11:38 PM   #11
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
check with member Truckseats out of Tri-Cities Washington, he will know for sure, or have them already..
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
