Hatch Handle Removal
I'm having some trouble getting the pin at the bottom of the shaft of the hatch handle on my Blazer. PB Blaster doesn't seem to be working. Here's the thing: the handle itself is actually broken off anyway so it's junk anyway. Knowing that, what would be my best course of action? I'd like to get this replaced. I'm getting awful tired of that thing banging every time I go over a bump.
![]() Join Date: Dec 2002
Re: Hatch Handle Removal
I had the same problem. took a grinder and cut the shaft then replaced with garage door handle from home depot
That's what I was thinking. Did you just cut it right where the pin goes through? Did it come out alright after that?
![]() Join Date: Jan 2012
Yup like pound said, cut it off with a grinder (I used a hack saw) about where the pin is but save the whole cam mechinism if possible. Knock the square stock out of the cam and slide in a garage door handle (I got mine at Lowes, but China makes em all the same) then pin it on the other side of the split ring. Instafacto new handle! I know your pain mine came off and stayed off for two years because I was looking for a replacement handle. Not enough money or availability for that, I kick myself for not doing it sooner!
![]() Join Date: Aug 2012
I searched for posts on hatch handle removal - great posts here on the forum have helped me get to this point but I can't seem to get the handle to slide out. I removed the cotter pin (well tried and it broke). The handle does not slide/move in and out, it seems to be stuck and moves in unison with everything.
![]() Blazer Hatch Handle by Luftwaffepdx, on Flickr I have disconnected the side bars, removed the angle retainer palte but can't get any farther. Any suggestions? I have sprayed it with CorrosionX but it doesn't seem to be doing anything. Do I need to give up and saw off. Will applying heat help ? - that might be tricky with the fiberglas. I don't want to mess up the handle if I can help it. The chrome is in great shape - I just need to have it rekeyed and secure side bars so the handle is oriented horizontally rather than poping up on one side when reinstalled. Thanks for your help. |
![]() Join Date: Jun 2004
I'm in the same place as PDXk5. Anyone know how to get this apart?
4oldcars Driving: 1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado The ones I let go: 1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed |
![]() Join Date: Nov 2007
Same here. Once my used handle comes in, I'm likely just going to cut it in half.
Well, use guys better figure it out soon, or i wiil be shipping alot of broken handle parts
![]() HAPPY HOLIDAYS
I would suggest you cut it to get it out and then punch it through. If you were reusing. I got mine free with a c clamp at one end of the shaft and the other end hooked to the metal bracket and pressed it out.
