Old 12-25-2012, 06:58 PM   #1
68gmsee
Active Member
68gmsee's Avatar
Re: Where to find door weatherstripping
I bought mine couple of years ago from GMCPauls. At first the doors were somewhat hard to close so I had to adjust the striker out a little. After a summer they will mold to the door.
Leave a little more than needed at the bottom where the two ends meet. Maybe 1/4 inch. Mine seemed to have shrunk about that much but I think it was my fault for not pushing the corners in all the way. Overall, very pleased with them.
I bought window channel kit and seals at the same time and found out that with the cab sealed tighter it is easier to close the door slowly until there's about 6 inches left then push it faster to close it.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 12-25-2012, 10:14 PM   #2
1972RedNeck
1972RedNeck's Avatar
The OP's '72 should have a cab vent so it should close fine. That is a nice problem to have though. My cab corners provide plenty of ventilation.
Thank you much for your service.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
