Old 12-24-2012, 12:22 AM   #1
big10ratrod77
big10ratrod77's Avatar
replacing rear leaf spring bushings
I am planning on replacing the rear leaf spring bushings on my 79 c-10 with polyurethane units, how hard is that? I replaced the ones on my 73 Plymouth duster and it was a major pain in the butt. If it was not too bad I would replace all of that while I had the bed off. So if any of yall have attempted this let me know if it’s worth the time and effort.
77 chevy BIG 10 350/sm465/12bolt w 3.73 bout 240 horse power NO power steerin
79 chevy 1/2 ton 250/three on the tree/3.08s soon to get built 250/floor shift conversion/3.08s
81 mercedes 300d 25 MPG
77 chevy BIG DOOLEY 454/sm-465/14 bolt 4.10s "fully loaded"
73 plymouth duster 225 slant six/230 3 speed/8 1/4 trying to acheve 300 horse six http://www.cardomain.com/ride/3135091
'77 chevy trucks. built to stay tough.
life is short build a hot rod
big10ratrod77 is offline   Reply With Quote
Old 12-24-2012, 12:30 AM   #2
cory d
cory d's Avatar
Re: replacing rear leaf spring bushings
i plan on doing this soon. panhard bar after that
cory d is offline   Reply With Quote
Old 12-24-2012, 12:31 AM   #3
Telecasterjoey
It will be easier with the bed off that's for sure, the big problem I had when doing it was getting the bolt out of the bushing, the inner metal sleeve on the stock bushings was rusted onto the bolt so bad I had to melt the bushings out and then cut the metal outer sleeve out of the leaf springs. It's not too bad just labor intensive.
Good luck!
Telecasterjoey is offline   Reply With Quote
Old 12-24-2012, 12:42 AM   #4
big10ratrod77
alrite then ill plan on doing that then, that aint to bad probly wouldnt hurt to put some antiseeze on the bolt to prevent future problems to, thanks bud
Old 12-24-2012, 12:49 AM   #5
INSIDIOUS '86
INSIDIOUS '86's Avatar
Wouldn't recommend urethane. New rubber is good but urethane isn't good for much other than a drag racing standpoint
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 12-24-2012, 01:10 AM   #6
big10ratrod77
I used a full PST front end kit and rear bushings on my 73 duster and I was totally satisfied, it completely changed the car as far as how it handles and it still rides smooth going down the road. i was worried that it would beat the living daylights out of you but when i got to out and started driving it, it rode great. that’s the only reason I thought about doing that to my 79 you know I am planning on replacing it anyway why not go a little better than stock
Old 12-24-2012, 02:48 AM   #7
INSIDIOUS '86
Well the rear has to articulate so on a light rear end like a truck that can make it bounce and wobble on a turn. Plus our trucks lean more. I have an energy susp kit on my truck and love it as well. I would recommend a panhard and rear swaybar. That will make a night and day diff as well.
Old 12-24-2012, 03:11 AM   #8
cory d
cory d's Avatar
would new rubber bushings in the leafs and poly bushings in the shackles be a better choice?
Old 12-24-2012, 03:43 AM   #9
INSIDIOUS '86
That's how mine are setup since they are lowering shackles. I still wobble like crazy at speed if you twitch the wheel. I need a panhard hardcore.
Old 12-24-2012, 06:48 AM   #10
bk2life
squeak squeak squeak...
rubber in leafs will make you smile
bk2life is offline   Reply With Quote
Old 12-24-2012, 09:08 AM   #11
88Jimmy4x4
88Jimmy4x4's Avatar
I use these on all my trucks and blazers, they are greasable so no squeek
http://offroaddesign.com/catalog/greasebushings.htm
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 12-24-2012, 09:20 AM   #12
big10ratrod77
that makes sense i gotcha now ill probly put rubber bushings in now thanks for the help bud (i guess its like my dad has always told me "stock is best" ), thats also why i ask for others imput befor i spend to much money. i installed a rear sway bar about 2 months ago and i am totaly excited about the differance it made in the truck
Old 12-24-2012, 10:05 AM   #13
bigd65
bigd65's Avatar
I did the WHOLE poly bushings on my 85 that I use to have. The Body bushings , suspension, everything and man it was stiff, handle very well... But stiff and yes it was a pain in the but, the whole job was
2004 Silverado Crewcab
1972 Chevy Monte Carlo
2017 Chevy Tahoe
bigd65 is offline   Reply With Quote
Old 12-24-2012, 11:29 AM   #14
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Polygraphite!! Best of rubber and poly!! I'm installing lowered leafs with polygraphite bushings this spring!!
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 12-24-2012, 12:04 PM   #15
N2TRUX
Happy to be here
N2TRUX's Avatar
Winner, Winner, winner! If you want a better ride AND quiet bushings, upgrade to Polygraphite. By combining graphite with polyurethane you have a bushing thats not quite as hard a pure urethane, and is self lubricating due to the graphite content.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-24-2012, 01:02 PM   #16
INSIDIOUS '86
Those polygraghite bushings are still hard as hell. The biggest thing is they don't squeak because of the graphite.
The best way to make your bushings and susp last forever? Zero fittings. Drill and tap for zerk fittings. I did that to my front end control arms.
Old 12-24-2012, 02:47 PM   #17
Billy81
Billy81's Avatar
X2, I used their greasable bushings on my K5 front and back.
Billy81 is offline   Reply With Quote
Old 12-24-2012, 03:49 PM   #18
i heart square bodys
i heart square bodys's Avatar
the biggest issue you will have is getting the bolts out of the bushings. I solved this issue by melting the ends of the bushings to give me space to get a grinder in and I cut the bolts off both on both sides of the shackle. (with the box off, makes life a lot easier) . to get the bushing out I drilled all of the rubber out and knocked the centre out still leaving the thin metal sleeve inside the leaf. to get the sleeve out I cut a notch in it all the way across the sleeve with a sawzall and peeled it up with a screwdriver, this broke it free enough to knock it out with a hammer . clean the rust out of the leaf spring and apply some anti-seize and knock them in with a mallet . if this doesn't work put a length of threaded rod though the bushing with nuts and big washers on both sides and pull them in . I have P/U bushings in my shackles and rubber in my leafs.
i heart square bodys is offline   Reply With Quote
Old 12-24-2012, 09:44 PM   #19
88Jimmy4x4
88Jimmy4x4's Avatar
Thanks, I was beginning to think I was the only one that even knew about these
1991 GMC Jimmy 4x4
Old 12-24-2012, 11:57 PM   #20
zirk
zirk's Avatar
I'm putting drop shackles on mine, just to make it easier I got new bolts and bushings, and used a cutting torch to burn the bushings/bolts out.. probably 10 minutes of work..
Chevy runs in my blood
zirk is offline   Reply With Quote
Old 12-25-2012, 08:59 AM   #21
D13
D13's Avatar
I can find poly easy but not with graphite. Who sells polygraphite? And if teh decision is to grease them is silicone grease the stuff to use? My truck is an all weather driver, 35K a year, and the Michigan road salt seems to dissolve grease.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 12-25-2012, 03:10 PM   #22
2ndstoryslam
2ndstoryslam's Avatar
http://www.p-s-t.com/
2ndstoryslam is offline   Reply With Quote
Old 12-25-2012, 09:09 PM   #23
83GMCK2500
Where can a guy who was happy with his OEM rubber bushings & mounts buy quality replacements?
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 12-26-2012, 04:53 AM   #24
spencer_41188
spencer_41188's Avatar
rubber vs. polly hummm if you got a shop press and you wana replace them again in 20 years go with rubber
i went with polly because all i have is basic tools my spring bolts broke so i had to pry, hammer, grind, and saw the springs out then i drilled a pilot hole in the broken bolt, then a hole saw to cut the rubber out, then i took the sawzall and cut the outer ring of the bushing in 2 spots about 3/4 inch apart and folded it togeather .... didnt take all that long but the polly bushings just smear alittle grease on them and tap them in with a hammer put some anti seese on the 9/16 grade 8 bolt and tightened her in place
only took 5 or 6 hours but i didnt pay a michanic there going rate lol
88 gmc v3500 bonus cab classy chassy conversion, 454, nv4500, np205, dana 60 front with spool, 14 bolt ff cac rear with locker.
spencer_41188 is offline   Reply With Quote
