steering column plug question
Hey guys, I wrapping up the wiring under the dash of my 66 and have a question. The 8 pin plug that plugs into the two 4 pin plugs from the column just hangs loose. There appears to be a metal tang on it that might snap into a clip somewhere but I can't figure out where it clips. Does anyone have a clue where this may hide out at. The curvature of the plug suggests somewhere along the column?
Re: steering column plug question
anyone, I hate the plug just hanging there and I don't want it tie wrapped out of the way.
There is a bracket that bolts under the dash that the plug clips to... I will try and post a pic later
1965 long bed ( grandpas old truck ) 1964 long bed BBW Custom Cab 1966 Short stepside 1964 long bed 1965 long bed Custom Cab, factory air, V-8, powerglide |
Can Anyone help, simple as looking under your dash and seeing where it clips to. I think I missing something on my column...
Scrapper 1
Boy i'm surprised that your not wanting to change your column.Any problems with your turn singles switch or anything else.there is a bent little square peace of metal that has a cut throw it and the metal tab squeezes into it Me i just rerouteing the wires to loop over one of the insisting wire looms to keep it out of the way or a Zip tie here is the bracket i think its bent but its suppose to lay flat to keep the harness out of view
