Old 12-15-2012, 02:54 AM   #226
BlueJeep
BlueJeep's Avatar
Re: My version of the s10 swap
And pictures of how I modified the transmission crossmember:
And here you can kinda see how well everything is tucked up. The oil pan hangs down just a touch, but not enough to worry about:
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 12-15-2012, 03:01 AM   #227
BlueJeep
BlueJeep's Avatar
And since the motor is in for good, I was able to start mocking up a few other pieces. It's obvious to me now that I need to do some major modifications to the passenger side inner fender. I'm using Kwik performance brackets for a Sandin compressor for A/C, and they hang way off to the passenger side. Might have to figure out something for the support rod on that side...
Here you can see that I'm going to have to get a straight water neck, the factory one won't work:
I originally thought I could put a swell in the rod to clear the coil pack. A/C compressor is going to pose a much bigger problem though...
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 12-15-2012, 03:08 AM   #228
BlueJeep
BlueJeep's Avatar
And that brings me to tonight. Tonight's project has been getting the rear axle ready to go. I decided that I wanted the pinion offset 5/8" to the passenger side, same as the engine.
Hope I measured correctly:
A little dry fitting:
And now it's ready to be welded. My wife usually spins axles for me when I cut them down so I can weld them in one pass, and she was asleep so that'll have to wait until tomorrow. Measurements were spot on, now I can order the shafts and put it back together.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 12-15-2012, 04:51 AM   #229
Chevette
Chevette's Avatar
Nice work, BlueJeep. Looks good.
56 Chevy PU
http://67-72chevytrucks.com/vboard/s...d.php?t=531955
Question: Know how to sell your truck for $50,000?
Answer: Spend $100,000 building it.
Chevette is offline   Reply With Quote
Old 12-15-2012, 10:33 AM   #230
Wheelie
I like that narrowing fixture you got there. I always cringe when I see someone try to narrow a housing without one. Your project is coming along real nice!
My '59 Build Thread
Wheelie is offline   Reply With Quote
Old 12-15-2012, 11:35 AM   #231
BlueJeep
BlueJeep's Avatar
I've been using the jig for many years, and have built countless axles with it (mostly semi-float dana 60's). It's the only way you can ensure the housing ends are aligned with the carrier bearings. Last week I got some new pieces to make it easier than using a "dummy" 3rd member.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 12-15-2012, 11:38 AM   #232
BlueJeep
BlueJeep's Avatar
Originally Posted by bk2life View Post
what is a clean and strip disc?
Sorry for not responding sooner, this is a clean and strip disc:
http://www.amazon.com/Norton-Non-Woven-Depressed-C... http://www.amazon.com/Norton-Non-Woven-Depressed-C...
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 12-15-2012, 01:55 PM   #233
_Ogre
_Ogre's Avatar
fender brace clearance: remember your motor will rock back and forth under acceleration
you should have at least an inch clearance to anything fixed to the body
i used to work for dana heavy axle division, the machine that swedges the axle tube down is a pretty amazing machine
the ford superduty axle tubes had a 9/16 wall tube that got swedged down 1/2 inch
shop air compressor timer
Old 12-15-2012, 04:07 PM   #234
Chevette
Chevette's Avatar
http://www.amazon.com/Norton-Non-Wov...and+strip+disc
How are those wheels lasting for you? I bought three "Gator" brand wheels and they wear out way too fast for me. To make matters worse, I paid $19.49 per each for them. Would like to find one that gets a bit of stripping done before it's ready for the garbage pail. Maybe the ones you're using will last better?
56 Chevy PU
Old 12-15-2012, 04:22 PM   #235
BlueJeep
BlueJeep's Avatar
Yes, when it's done there will be adequate clearance around all things that vibrate. I'd like to see how they do that swedging, can't quite picture in my head how it's done. Can you tell me what the advantage of doing that is over a consistent diameter?
Cleaning up the axle was pretty much 2/3 of one of those discs. But, I wasn't very careful around the sharp edges and I've used it for a few other things to so I'm pretty happy with the life of it. If I were just doing rusty sheetmetal panels I think it'd last a long time.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 12-22-2012, 01:28 AM   #236
BlueJeep
BlueJeep's Avatar
I had a little bit of time this afternoon, so I started the transmission tunnel. I began with some paper patterns and a sheet of 20 gauge. To bring it up to floor level, I rolled a flange around the edge (Shannon I'm learning from your builds). I'll be welding it in when finished, but for now it'll be easy to take in and out to make adjustments.
Looking good from the side:
Then I had to try out a new toy:
And here's the rough idea. A lot of trimming and fitting to go, but feeling pretty good about where I'm headed with this.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 12-22-2012, 01:34 AM   #237
BlueJeep
BlueJeep's Avatar
These also arrived today:
Now I've got plenty to do when I have "spare time" around the holidays!
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 12-22-2012, 02:47 AM   #238
cleanshaven84
cleanshaven84's Avatar
Looking good Blue!
1949 GMC Pickup
Project "No Time '49"
Currently working on S-10 chassis swap.
Philippians 4:13 - "I can do all things through him who strengthens me."
cleanshaven84 is offline   Reply With Quote
Old 12-22-2012, 10:51 AM   #239
oldman3
oldman3's Avatar
Nice job....Jim
oldman3 is offline   Reply With Quote
Old 12-22-2012, 12:44 PM   #240
Chevette
Chevette's Avatar
Great job on the sheet metal! Nice looking slip roll. How big is the throat? Your truck is coming along very nicely.
56 Chevy PU
Old 12-24-2012, 06:18 PM   #241
panelrodder81
Doin' it live!
panelrodder81's Avatar
@BlueJeep - interested in your motor mounts. I'm doing 5.3 swap on my '53 from the 5.7 that was in there before. The position of your motor looks great, not to deep or tall like some get.
Any info or pics?
-Panelrodder
-Panelrodder
1953 GMC Panel truck - 'Curly'
1961 Chevy Suburban - 'Larry' - Sold
2005 Harley Sportster - 'Shemp'
panelrodder81 is offline   Reply With Quote
Old 12-24-2012, 07:00 PM   #242
BlueJeep
BlueJeep's Avatar
It's the 24" (beginners) model.
Any info or pics?
-Panelrodder
Let me know what you need/want. It's really easy to get anything at this point.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 12-26-2012, 05:45 PM   #243
panelrodder81
Doin' it live!
Well a couple pics would be the most basic request I guess. Are you using the stock ls mounts or something custom or something you purchased somewhere?
My motor came with some stock mounts and my first thought was to lower the motor in place and just see if they would even work. I've looked at aftermarket mounts and they are crazy expensive for just some metal plates so I'd like to see if I can use what I've got or modify them before dropping coin on new ones.
-Panelrodder
PS: Your build is inspirational man and I'm gonna jack your batter mount in the fender well idea I think.
-Panelrodder
Old 12-27-2012, 01:52 AM   #244
BlueJeep
BlueJeep's Avatar
-Panelrodder
Thanks! I used motor mounts from Carshop.com. I'd likely build my own if I did it again, mainly because since they came all welded up I had to cut them apart to start fitting then to my frame, which was more work than I wanted. If you go back in the build thread a page or two you'll see lots of great pictures of the motor mounts and how it sits in the frame. I have a couple sets of stock ones too, but I think it would take too much to be able to re-use them as they're bulky and not flat.
Here's a good picture showing how low the motor sits in the frame:
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 12-27-2012, 02:01 AM   #245
BlueJeep
BlueJeep's Avatar
Today was spent working on the transmission tunnel. I did some shrinking around the rear edge of the tunnel to get it the shape I wanted and then spent a lot of time trimming. I went a little at a time so as not to cut to much off, and I'm very happy with how it turned out. I'll have a little finish work when I flip the cab back over, but for now it's looking good!
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 12-27-2012, 02:09 AM   #246
BlueJeep
BlueJeep's Avatar
And now that I don't have to be in and out of the cab so much, it's time to finish some other things up. I waited on installing the cowl panel until I had the door hinges rebuilt. I'm trying to get the gaps as good as I can get them, without spending too much time on them. I'm just building a driver, and periodically I have to remind myself of that.
So, I hung the door to get started and then proceeded to adjust, and adjust, and adjust the cowl panel. It really doesn't follow the profile of the door very well, so that will be modified more tomorrow.
I also didn't like the crater that was formed when the panel was overlapped like original, so I cut it out and will butt-weld a piece in there.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 12-27-2012, 10:40 AM   #247
oldman3
oldman3's Avatar
Trans hump looks great, I agree those repop panels can be a bear to make work...Jim
Old 12-29-2012, 03:12 AM   #248
BlueJeep
BlueJeep's Avatar
Tonight I spent a few more hours working on the cab. I have the cowl panel on for good and the driver's side cab corner. Just a few more things to wrap up before I call that side done.
Here's how much I had to spread the cowl to get it to somewhat line up with the door.
I'll have to do the same thing with the bottom of the cowl too, but I don't have good access to it right now so that might wait until I pull the cab back off.
The cab corner turned out pretty nice, some finish grinding still required.
And here's where I'm at with the profile of the door and the profile of the back of the cab. I'm not looking for perfection here, but I am going to get it better than this:
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 12-29-2012, 12:54 PM   #249
oldman3
oldman3's Avatar
Going to spread back of cab to match door, like the front???Jim
Old 12-29-2012, 05:26 PM   #250
BlueJeep
BlueJeep's Avatar
Yes, that's exactly what I'll be doing.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
