Old 12-30-2012, 04:41 PM   #1
72K20SUBN
72K20SUBN's Avatar
1972 Tilt Column housing removal
Hello All,
I'm attempting to remove the housing off the 1972 Chevy Suburban Tilt so that I can replace the wiring, gaskets, and repaint before reinstalling into vehicle.
In order to fully dissassemble, I need to get to the tilt pivot pins, but the outer shroud (housing) covers these pins. It appears the outer shroud would simply pull off, as I don't see any screws/pins/snaps holding it in place. But there is some unknown force that I can't see holding it down tightly.
Has anyone had experience in dissassembling and removing this piece? If so, I could really use some pointers on this.
Thanks much.
72K20SUBN:
- '72 Suburban K20
- '72 Cheyenne K20
- '71 Custom20 Deluxe 4x4
- '63 Pontiac Bonneville 2Dr HT
72K20SUBN is offline   Reply With Quote
Old 12-30-2012, 05:10 PM   #2
29od1
Re: 1972 Tilt Column housing removal
Take your time and be patient. They're tight fitting. You may be able to take a puller and hook under the inner lip and tap with a rubber mallet to remove it. No special trick that I know of, just patience and perseverance.
29od1 is offline   Reply With Quote
Old 12-30-2012, 05:55 PM   #3
john
member #16
john's Avatar
I used a piece of wood. Just a small piece of lath in one of the holes and a rap with a small hammer and it will pop off.
john is offline   Reply With Quote
Old 12-30-2012, 08:44 PM   #4
med.bronze
med.bronze's Avatar
I used to do this in similar ways as mentioned above until I got a service manual and got all the Kent-Moore tools to rebuild an entire column. This is the one that removes the cover. I got it on ebay for around 15 bucks and it works great.
1972 Cheyenne Super 10 SWB,bucket seats,dealer cruise,tilt,tac,a/c,shoulder belts, 350/350
1971 K-10 Custom Deluxe
1971 K-10 Custom
med.bronze is offline   Reply With Quote
Old 12-30-2012, 09:07 PM   #5
sjarrett71
sjarrett71's Avatar
I've used a small gear puller and was real careful. Didn't damage it at all.
-Scott-
sjarrett71 is offline   Reply With Quote
Old 12-30-2012, 11:33 PM   #6
hugger6933
Take a pick or a small screwdriver and make almost a scoring action around the bottom of the collar where it is pressed onto the column. It will have dirt gunk and all kinds os stuff there at the mating surface and that will act as a binder.Also there are a couple of small slots in a couple of locations around the column under the collar and after going around it several times you can pry ever so gently in those tabs to see if it gives any. All the while at the top you can pull upp on the collar from the edges I used my fingers but I have big hands and they are pretty strong. I have the service man. here if you need me to look up the kent moore tool number for you send me a pm and I'll do that. I have pulled 2 or 3 in the manner in that I've described, and I think the key is the pick and scoring around the collar first at the bottom. Jim
hugger6933 is offline   Reply With Quote
Old 12-30-2012, 11:37 PM   #7
29od1
What's the part number on that tool? That looks like it'd work awesome!
Old 12-31-2012, 12:14 AM   #8
med.bronze
med.bronze's Avatar
it's j-22708
1971 K-10 Custom
Old 12-31-2012, 12:22 AM   #9
med.bronze
med.bronze's Avatar
j-22598 will also work, I thinks it's exactly the same but a later part number
1971 K-10 Custom
Old 01-03-2013, 01:56 PM   #10
72K20SUBN
72K20SUBN's Avatar
Awesome, thanks for the replies. I've been tied up the last few day's and haven't gotten around to anything, but I like that a correct tool is available for it.
I'll gently try the home-grown techniques, and if I have no luck, I'll then move to a search for that tool.
It still blows my mind how powerful this forum can be!
72K20SUBN:
- '72 Suburban K20
- '72 Cheyenne K20
Old 02-13-2013, 01:13 PM   #11
ChevyCruizer
17's too small
ChevyCruizer's Avatar
Also try spraying the area around the base of the housing with your favorite penetrating oil. I got mine apart last night pretty easily after soeaking it. I did work from side to side to keep it from kinking/binding.
68 C10 SWB SS 5 lug power disc brake conversion 2.5 inch drop spindles van tilt column Air Ride Technologies Cool Ride air bag kits Performance Online tubular upper control arms and shock relocator kits ECE super track panhard bar 1 piece side windows
ChevyCruizer is offline   Reply With Quote
