1964 Front End Question
Hi guys, there is a little part of the front end of my panel that is mangled. How do I remove that lower part to replace it? what is that part called? I hope It not too crazy to replace that. Thanks guys.
Re: 1964 Front End Question
'Lower valence panel' I think?
It is all one part of the part above your Grill....it bolts to your core support
Measure with a yard stick Mark with Chalk Cut with a torch ![]() Built it yourself, don't count on others to to do it for you or with you. It will never get done |
60-66 Nut
If you aren't wanting to do any cutting and welding, you will have to replace the whole grill panel. That is one piece between the fenders, and between the bumper and the hood.
Thanks for the help guys. Looks like i'll be replacing the whole piece.
Make sure you get one that will fit your 64, I thought they were all the same. I bought one at a swap meet and found out it was off a 62? The notches above the frame were really tight for my 66 GMC. I got it on but it is touching the frame horns.
60-66 Nut
I believe '63-'66 are the same grill panel.
If that's the only damage, I'd remove the bumper and fix it.
1963 is actually different. 1964-66 are the same. 1963 will physically bolt in, but the grill mounting holes are different.
1988 C1500 Regular Cab, Long Bed, 2WD. |
