Old 12-30-2012, 09:03 PM   #276
eldogg
eldogg's Avatar
Re: How about some pics of Static dropped 60-66
Originally Posted by LostMy65 View Post
I searched some of your posts, and I couldn't find more pics of this truck.
I would sure like to see more of this one.
Sorry I've been slacking on this truck. It's my little brother's truck and I have a bad habit of working on paying customers stuff first.
I'm machining the lower control arm shafts for more caster and hope to have the front done in a couple of weeks. I'm gonna start a build thread on it then. Stay tuned.
eldogg is offline   Reply With Quote
Old 12-30-2012, 09:12 PM   #277
LDO
LDO's Avatar
Here is mine. 5" CPP drop springs in the rear. 3" CPP drop springs in the front that have been cut down 'a little'...
I'm actually in the process of going thru the front suspension with drop spindles to improve the suspension geometry. Ball joints look like the buttons on a fat man's coat!
LDO is offline   Reply With Quote
Old 12-30-2012, 09:53 PM   #278
HouldenCaulfield
LDO, looks great! What is your wheel/tire combo?
HouldenCaulfield is offline   Reply With Quote
Old 12-30-2012, 10:03 PM   #279
LDO
LDO's Avatar
17x7 on 225/60-17s in the front, 18x8 on 255/55-18s in the rear.
I love the look and it actually rides pretty good.
Old 12-30-2012, 11:36 PM   #280
steve'62
steve'62's Avatar
LDO, looks effing sick!luv it
steve'62 is offline   Reply With Quote
Old 12-31-2012, 10:08 AM   #281
GMC66
GMC66's Avatar
Nice truck LDO!
GMC66 is offline   Reply With Quote
Old 12-31-2012, 10:26 AM   #282
LDO
LDO's Avatar
Thanks everyone. Gotta re do the front suspension and it has been a pain figuring what parts to use but this forum and its members have been a big help.
Old 12-31-2012, 11:16 AM   #283
Red65C10
Red65C10's Avatar
Very Nice
Billy
65 C10
............................... ____
................ ________-|___\____
.;.;;.:;:;.,;.|__(O)___|____/_(O)|
_______________________________
P.S. Send truck money !
Red65C10 is offline   Reply With Quote
Old 01-05-2013, 03:52 PM   #284
peltjd
peltjd's Avatar
My 1965 C10 static dropped. 2 coils off the front. 4" blocks and 1 coil off the rear. About to be bagged in a couple of months. Stuff is in the mail.
peltjd is offline   Reply With Quote
Old 01-05-2013, 07:01 PM   #285
HouldenCaulfield
That looks nice pelt! What size tire you running?
Old 01-05-2013, 07:44 PM   #286
peltjd
peltjd's Avatar
Thanks, I'm running p235/75r15. My buddy jusspassnthru is running a smaller tire and it looks lower but I like the bigger tire.
Old 01-05-2013, 07:45 PM   #287
peltjd
peltjd's Avatar
I've also added the custom cab trim piece and dog dish poverty caps since this was taken. I have a few more pictures in my gallery.
Old 01-08-2013, 02:09 PM   #288
CRZSWAP
Originally Posted by s11sean11 View Post
heres my 62 almost done now
what suspension are you running? That sits really nice
CRZSWAP is offline   Reply With Quote
Old 01-14-2013, 10:18 PM   #289
TxRat
TxRat's Avatar
found my springs not sitting in the front pockets right. they are now..
4-6 drop, parts from Scott Hot Rod Shop.
TxRat is offline   Reply With Quote
Old 01-15-2013, 10:23 AM   #290
GMC66
GMC66's Avatar
4 in drop Leaf spring and 2 in drop shackle rear, 2.5 spin and 1 inch springs front. Going to a 2 in front spring soon.
Old 01-20-2013, 06:09 AM   #291
chopboogie
Hey, I got a 64 GMC w/ rear leafs. I'm kinda new here, where did you get lowered leafs or are the garage built? Or does anyone know of a flip kit for the rear? Any info would be appreciated, thanks.
chopboogie is offline   Reply With Quote
Old 01-20-2013, 11:07 AM   #292
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
A "flip kit" is used to raise a leaf sprung truck.
(shackle flip is a 4X4 term)
There are drop shackle kits available that are essentially longer shackles for the back of the spring.
Drop leaves are also available and between the two you can drop the rear of the frame to the point of needing a "C-notch" on the frame.
HOWEVER... "C_notching" a leaf sprung frame is HIGHLY inadvisable since the back of the leaf sprung frame is an integral part of the structure of the suspension while a coil sprung frame is not....
Many people don't know that 63-66 GMC were not sold from the factory with coil sprung rear suspension so almost everything available for the 63-66 trucks is for the coil rear suspension.
You could swap to a Chevy frame but that is quite a bit of work, but then you would have the coil/trailing arm suspension that tons of stuff is available for.
Hope this helps.
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline   Reply With Quote
Old 01-26-2013, 02:29 PM   #293
robber grin
Post Re: How about some pics of Static dropped 60-66
chopboogie - not aware of a "bolt on flip kit" for the 64 but cutting and extending the rear shackles would get you a couple inches lower...
I'll have to dig around for a pic I had on the flip kit for the later leaf spring trucks (73-87) cause I think it would be doable to fab something similar for your truck.
Seems a flip and losing some leafs with a frame notch will get you down on the back end.
I'm doing a 4" coil spring / 2" block drop on my 62 C10 with a notch. 3" coils and 2 1/2" drop spindles on the front.
I have to wonder when it becomes necessary to raise the bed floors & tubs within the fleetside bed box?
keep us posted...
FOUND the pic
bob
robber grin is offline   Reply With Quote
Old 01-26-2013, 06:40 PM   #294
steve'62
steve'62's Avatar
All cleaned up!
Old 01-26-2013, 06:47 PM   #295
HouldenCaulfield
Beautiful truck Steve. What tire size and drop?
Old 01-26-2013, 07:23 PM   #296
steve'62
steve'62's Avatar
Coker 235/70/15, cragar 15x8, cpp 3 inch front drop springs, 5 inch rear. Just got the cpp disc upgrade and drop spindles, probably going to throw a 1" or 2" block out back.
Old 01-26-2013, 07:33 PM   #297
HouldenCaulfield
Thanks, I have the same CPP kit and will buy the spindles soon also. I look forward to seeing yours done. Great tire size.
Old 01-27-2013, 01:18 AM   #298
66-PMD-GMC
66-PMD-GMC's Avatar
The quickest way to take 4" off your ride height would be to put your axel on top of your springs rather than under them.
Check with CaptainFab on this forum. He has supplied several special suspension and steering pieces to friends of mine and everything was top notch quality.
If this is what all of you kids are calling a flip kit.. captainfab can probably help you out.
Projects..
440CID 2X4 Pontiac
Old 01-29-2013, 12:36 AM   #299
chopboogie
Thanks 66-PMD-GMC,
THat's what I was thinking about when I asked about a flip kit, to flip the axle above the leaf springs. I've seen them for late model trucks just not earlier trucks. I'll look up CaptainFab and check him out.
Chopboogie
Old 01-29-2013, 12:43 AM   #300
chopboogie
keep us posted...
FOUND the pic
bob
Thanks robber grin,
I'll look at this option, I'm comfortable with some minor fab work, body work scares me. It will be a couple months before I have anything to post. I hope to get started then when the weather breaks a little. I got a 4 month old plus 2 other kids, trying to keep them and mama happy leaves just a little time to play in the shop.
Chopboogie
