Transmission question, PLEASE HELP
Hello everyone,
I found a great donor truck.I previously asked about swapping my tranny from an auto to a manual. So now i found this great donor truck for a good price. It has a SM465 in it, but runs on a 350, and my truck runs on a 454 with a 700R4 tranny. The question is, if i was to buy this donor truck and swap the tranny, would everything bolt on or are there differences since the motors are different. I imagine the bell-housing wouldn't bolt on. If that is correct, can one of the bell-housings be modified or do i have to buy a whole bellhousing? If so can i please when from where can i find this bell-housing? Thanks in advance ![]() |
Re: Transmission question, PLEASE HELP
I have always been under the assumption that that trans will bolt right up to your big block I think they all share the same bell housing
Krazy Texan My Trucks are made with Wrenches not Chop Sticks 1967 GMC 3/4 ton "Johnny Cash" 1990 v1500 suburban 1967 Ford f100 Swb 4x4 "green bean" GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO |
The bell housings and trans will work. You will probably have to find a flywheel for the 454 I believe they are balanced different than the 350.
#4 | |
Moderator
![]() Join Date: Oct 2008
Get a 454 flywheel and sell the 350 flywheel. I'm not sure that 350 flywheel will even bolt up to the 454... Don't do it even if it does... The pressure plate and clutch disc are good cores.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
WOW a fast response ... thanks guys
so what i understand is that i should swap the flywheel only ? sounds easy and simple can i ask from where can i find a 454 flywheel of is there a specific brand i should be looking for ? |
#7 | |
any specific brand you recommend ? |
ZOOM! Hays!! They're all good.
What year is your 454? |
You could use just a balance plate with the stock 350 flywheel too! Saves some money.
http://www.summitracing.com/search?k...%20plate&dds=1 |
You better be sure of the year. THe 1987 and up chevy motors used a one piece rear main seal. Flywheel, bellhousing etc where different.
THe casting number behind the drivers side head will help. Also the numbers off the pad in front of the passenger side head will be needed to tell what you have.
And check the same numbers on the donor truck. Then look here to decipher it. http://www.nastyz28.com/decode.php |
#14 | |
#15 |
No No
just to put this out there different patter on the flywheel between small and big block. find out what year you engine is and order on for that year. the bbc flywheel from 66 up all use the same patter but different balance I had a heck of a time finding one for my vortec bbc that was the correct balance. if York just using this as a he platform you can get a stock replacement flywheel at any parts store about 80 for a new one
Posted from 67-72chevytrucks.com App for Android
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
#16 |
454 is an external balance engine. I don't think just throwing a flywheel in ther is going to work out.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
#17 |
Why wouldn't it work out. A dedicated 454 flywheel will be balanced for it. Or a balancer plate with a 350 flywheel that's nuetral balanced.
Easy peasey!! |
#18 |
all you need to change is the flywheel, from what i understand is, the 350 dont count for diddly squat, he wants t put the stick behind the big block, as far as useing the 350 flywheel, no it wont work, it doesnt matter what year the 350 is
#19 |
Bellhousings are the same. I have a 1 pc rear main engine from an '86 in my '78. Flywheels are definitely different though.
![]() 305 ci | TH350 | NP208 | 60k miles |
#20 |
thanks everybody, anyone tried this swap and is positively sure ?
#21 | |
i ask because id like a 2wd 700 for my truck... maybe we can parts swap and make up the difference with some cash? |
#22 | |
About the flywheel, its the 350 flywheel that you have? because from my understanding on the forum members, the 454 flywheel varies from the 350's. Thanks for the help and i'll get to you as soon as possible about the 700 btw, it a 2wd ![]() |
#23 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Here is what you need to know....
-Bellhousings are the same. Small block, big block, even six cylinders. The SM465 bellhousing will absolutely bolt directly to your engine. -454s use a different balance flywheel than small blocks and even other big blocks. You need a standard transmission flywheel for your 454. Bolt it on and go. Folks are muddying the water about the balance issue. Whether you get a used 454 flywheel or a new one, line it up and bolt it on and move on the the next thing. It's that simple. I say this as the guy who has built two prior big block trucks and now own a current 454 truck with an SM465 in it. It's sitting in my driveway right now. These are things I've learned first hand and done personally. |
#24 |
I took a 350 flywheel to a machine shop and had it balanced for a 454, never had a problem with it. That was a lot of years ago though, might not be cost efficient anymore.
![]() 1985 C10 2004 Avalanche |
#25 |
And I too used a 350 flywheel on a 454 using a balance plate and it worked great but then what do I know!!!
