Old 12-16-2012, 03:52 PM   #1
robber grin
Question 60-61 HOOD measurement
I have a 1960 Chevrolet C60 hood that measures 25 1/2" from back corner to side seam joint with the front panel (lights mount in).
I have a 1966 Chevrolet C10 hood that measures 37 1/2" at the same point.
Does anyone have a 1960 C10/20/30 hood that they could measure for me from the back corner to the seam/crease/joint where the panels meet?
Sure would appreciate it.
robber grin is offline   Reply With Quote
Old 12-16-2012, 06:09 PM   #2
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: 60-61 HOOD measurement
I think what you have is a lcf hood for the '60
Old 12-16-2012, 06:50 PM   #3
McCoyAZ
McCoyAZ's Avatar
If it helps at all a GMC hood measures 39.75 inches from the back to that seam.
McCoyAZ is offline   Reply With Quote
Old 12-16-2012, 08:13 PM   #4
jonzcustomshop
1961 crewcab
...and my chevy hood (60) measures the same- I got 39.5 , but it was a quick measurement..
Old 12-16-2012, 10:51 PM   #5
robber grin
I gotta figure it for sure since I hope to stretch it to fit my C10.
It's a fire truck hood - rust free - dent free - amazing condition.
I've got a couple of 2-6 hoods here that I can get the sections from then I just have to figure out the middle.
If anyone can double check and confirm the 39.5" then I'd be grateful.
Merry Christmas from Youngwood PA USA!
Old 12-17-2012, 09:54 PM   #6
robber grin
THANK YOU for checking and responding so quickly.
Old 12-17-2012, 09:58 PM   #7
robber grin
I appreciate that Jon!
I hate to be a PIA - but...
If you can double check and confirm the 39.5" then I'd be set.
Old 12-18-2012, 01:35 AM   #8
jonzcustomshop
1961 crewcab
no problem I will be out at the yard tomorrow, I have 4 chevs and a gmc I can check, I will measure them all to see if there is any difference.
Old 12-18-2012, 05:50 AM   #9
robber grin
Thanks again Jon!
Old 12-18-2012, 06:31 PM   #10
jonzcustomshop
1961 crewcab
ok, my hoods all measure 39 5/8, thats from the end of the hood to the center of the seam...and right inbetween 39.5, and 39.75
Old 12-18-2012, 06:37 PM   #11
robber grin
Exclamation Re: 60-61 HOOD measurement
THANK YOU JON!
Can you give me any tips on sectioning one of these since my C60 hood is 14 inches shorter?
Old 12-18-2012, 07:10 PM   #12
jonzcustomshop
1961 crewcab
I have been thinking about that, your best bet is finding a junk 60-61 hood that is either smashed in the front, or rusty on the rear corners, and then using that for the new piece in the middle...
I really dont think a 62-66 hood will be any help, their edge is sharper than a 60-61, and the top portion is a little bit narrower... this new hood was created by gm due to visibility complaints about the 60-61 hood...so its top, side and front profile is smaller than the 60-61.
another option ,is to cut it in 1/2 and then take 1 piece to a metal shop , and see if you can get them to roll out a piece of metal to bridge the gap that fits the profile of the cut portion.
I did this once on a 59 chevy dash that I was customizing, and it came out pretty good...
Old 12-18-2012, 09:28 PM   #13
robber grin
I'm hoping to make option one happen - ANYBODY got a 60-61 Chevy truck hood that's solid in the middle?
Old 12-19-2012, 03:33 PM   #14
robber grin
I think I have found one - I'll know pretty soon... thanks Tim.
Old 12-20-2012, 04:18 PM   #15
robber grin
I have been thinking about that...
Jon - what gauge metal would you get cut? 18? 20? thanks!
Old 12-20-2012, 05:37 PM   #16
jonzcustomshop
1961 crewcab
I am not sure which gm used on the hood, I would get a micrometer(?) and measure, unless someone else on here knows for sure...
when I did my dash I just had the guy use the same guage as the pieces I brought him
Old 12-20-2012, 10:05 PM   #17
robber grin
I'm trying to get a pice of 18ga cut to 13 7/8" for the section ...
Adding 14 inches to middle across the entire width.
So take away for the cut to split and figure a loss of @ 1/8th inch...
Leave 1/8th on either side of the section panel for butt-weld clamps...
Leaves 13 7/8" for the section width.
Sooo we'll see... Should be fun.
Old 12-20-2012, 11:01 PM   #18
jonzcustomshop
1961 crewcab
...also use your front clip for a mockup, either pull the springs, or hinges, latch the front of the hood, and line the back up with a nice gap to the cowl.
that way you can make sure it fits right.
if you have a piece made for the center have them make it a couple inches big, so you can trim it to fit.
Old 12-21-2012, 05:42 AM   #19
robber grin
I'm liking that mock up suggestion...
I was going to jig everything on 1" angle across some horses to hopefully keep everything in alignment, temporarily clamp small angle in between the sections at various points across the hood, then blend from both sides inward.
I could still do that on the mocked up front clip.
Thanks Jon!
Old 12-21-2012, 09:35 AM   #20
jonzcustomshop
1961 crewcab
another thing that should help is the support braces that run front-to back that are bolted in, I think the ones out of your 62-66 hoods are the same
Old 12-31-2012, 11:53 PM   #21
robber grin
Update... I got started working the hoods - measuring and checking everything...
I think I can still pull this off, but so far I'm unsure if I would be better off using the center out of the 61 hood and adding it in at the tape line on the 60 C60 hood OR using the C60 for patch panels for the 61 hood.
I want to set everything up level on horses, clamp the hood down, brace the inside, and do some more thinking before I saw anything.
