Old 12-31-2012, 08:31 PM   #1
Darren MagooGardner
vacuum guage purpose
I recently purchased a tach dash w vacuum guage from e-bay. I was wondering what the purpose of having one was? I was also needing to know what you hook it up to? what type of trucks did they come in?
Darren MagooGardner is offline   Reply With Quote
Old 12-31-2012, 08:41 PM   #2
hugger6933
Re: vacuum guage purpose
Darren, Techs will use a vac gauge to tell the basic condition of an engine by glancing at it. Also the vaccum will tell the ecoomy of an engine as in cruise mode the vac is high as you open the throttle the vaccum decreases. You can also set the idle mixture of your carb by them by turning in the idle screws until the gauge reaches its highest point then stop and do the other side. when you move the idle screws in and out it will move the vaccum up or down so the goal is to obtain the highest reading possible. The same goes for normal driving if you try to keep the gauge reading as high as it can be your mileage will be at its best. But you should keep in mind that tuning is gonna be hard to do with the smaller size of the guage that we have in our trucks. They are quite useful and fun to boot. If Iam not mistaken the hose will need to be hooked into manifold vaccum, being that it is under the throttle plates of the carb. Jim
hugger6933 is offline   Reply With Quote
Old 12-31-2012, 08:51 PM   #3
jocko
jocko's Avatar
this might help: http://www.secondchancegarage.com/public/186.cfm
Have seen it passed around in a few other posts. It is often used IN the cab as a "let off the gas, you're getting horibble gas mileage" gauge, but - in these trucks, kinda unavoidable. But a handheld vac is most useful for tuning under the hood when jimmying carb settings, etc. I installed a Pontiac Vac Gauge in my 66 and went thru the "how do I hook this thing up" question as well. Must be hooked to a "full time" vac port. So, as hugger points out, past the throttle plates is correct.
Old 12-31-2012, 09:00 PM   #4
Darren MagooGardner
Good info guys. thanks. But what trucks came stock w them?
Old 12-31-2012, 09:02 PM   #5
Livrat
Member #1049
Livrat's Avatar
They came as an option in the medium duty trucks.. (C40/50/60)
Livrat is offline   Reply With Quote
Old 12-31-2012, 09:06 PM   #6
SS Tim
SS Tim's Avatar
The gauge was used on medium duty trucks with Hydrovac brake boosters.
SS Tim is offline   Reply With Quote
Old 12-31-2012, 09:22 PM   #7
truckster
truckster's Avatar
I had one in my old motorhome. Mostly it just scared the crap out of me any time I touched the accelerator pedal.
truckster is offline   Reply With Quote
Old 12-31-2012, 09:28 PM   #8
JCD
JCD's Avatar
They register the magic..
J.
1972 Custom Deluxe Highlander C20
1971 Javelin SST New Project
1971 Demon 340
1969 SS El Camino
1968 SS RS 396 Camaro
1967 Barracuda Formula S
1965 140/4sp Corvair Monza Convertible
Sorry, but I don't do Fords.
JCD is offline   Reply With Quote
Old 01-01-2013, 11:13 AM   #9
Darren MagooGardner
thanks for all the info.I cant wait to get mine in and see how well it works.
Old 01-01-2013, 01:02 PM   #10
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Tach dashes with vacuum gauges are know for shorting out and causing a cab fire. This is why they were discontinued. I am happy to help you out of your problem though. I will give you $50 for it in working condition so I can use it for parts! ;o)
prostreetC-10 is offline   Reply With Quote
Old 01-01-2013, 01:51 PM   #11
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Does ths mean it wasn't available as an option on C10's-20' and 30's ?
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 01-01-2013, 02:16 PM   #12
SS Tim
SS Tim's Avatar
Not as an RPO that I have been able to find. There is code Z72 Vacuum Reserve Tank, Gauge and Warning Light. But again this is a Medium Duty Truck option.
Old 01-01-2013, 03:30 PM   #13
1972RedNeck
1972RedNeck's Avatar
I thought there was somebody on here with a manual throttle and vac gauge (no tach) in a C10. I *thought* it said that it was factory. That was a while ago though.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 01-01-2013, 05:01 PM   #14
SS Tim
SS Tim's Avatar
May have been. There are a lot of interpretations as to "factory". It is possible that a fleet order truck had a vacuum gauge for some reason, just unlikely. Not sure why though as it is really too small and poorly located to be a driving aid.
In the medium duty trucks it was an important part of the braking system to have vacuum on call and lots of it for the Hydrovacs, hence the gauge for trending and the light for a "too late dude" warning.
If there is a light duty that has it called out for on the SPID I would like to see it. The only possible C30 application I can think of might be a 14K GVW C30
Old 01-01-2013, 11:59 PM   #15
Darren MagooGardner
I dont think I ever heard that one before.Has any one else heard of this?
Old 01-02-2013, 12:18 AM   #16
too much stuff
Roadtrip!
too much stuff's Avatar
Correct, not available on 10-30 series that i am aware of.
I think he is yanking ya trying to get your dash for $50... All in good fun i am sure...
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 01-02-2013, 12:37 AM   #17
Marko3002
Marko3002's Avatar
My 72 has a vac guage. Looks factory, on the right side of the column.
Marko3002 is offline   Reply With Quote
Old 01-02-2013, 12:38 AM   #18
prostreetC-10
My Carbon Footprint
My bad.....totally messing with you because the vacuum gauge is something that I think 99.738% of us would love to have. Heck, even if it didn't work it would balance out the gauge cluster!
Old 01-02-2013, 01:18 AM   #19
SS Tim
SS Tim's Avatar
It looks factory because it is factory, but only in larger trucks. The clusters are very similar and the parts can be swapped. Twenty years ago you would see a magazine article oh and ah over a "rare factory vacuum gauge" in their write-ups on some "restored" truck. Often these trucks were a combination of years and parts to get a "look". Generally this included bucket seats, shoulder harnesses, rally wheels and a "comfort grip" steering wheel. Even today people are still seeking the vacuum gauges out more for status than real usability, I feel. The heavy truck air pressure gauge is another popular cluster addition now that air suspensions have become prevalent.
But if yours is listed on the SPID I would very much like to see a picture of it.
Old 01-02-2013, 01:22 AM   #20
Darren MagooGardner
you aint rite for that...you had me doin research on the subject,,,I am paranoid about cab fires. I did see a truck awile back that had a tach and had a cab fire..
Old 01-02-2013, 01:38 AM   #21
prostreetC-10
My Carbon Footprint
Vacuum is air....would be hard to have a cab fire due to an air leak. LOL My bad still!
Many on here will agree that I aint right for a lot of reasons.
