#26 |
![]() Join Date: Feb 2010
Re: new t56 magnum trans complete w/speedo gear for uor trucks
are you doing coilovers in the back?
my build threads, 68 pro touring, auto cross c10 (mid life crisis) http://67-72chevytrucks.com/vboard/s...d.php?t=464109 website http://www.sauersgarage.com/ |
#27 |
No, I went with the Hotchkis rear suspension set-up. It came with the conventional Bilstein shocks. Would coil overs be a better set-up you think?
#28 |
Just checking to see if you found out anything about the shipping?
#29 |
The size of your tire is determined on what your final gear ratio is in your transmission as well as your rear end gear ratio. Im trying to figure this out as well right now. It's very overwhelming! To do it right you have to get everything to jive correctly.
#30 |
just got home from hosiptal, been there all weekend. i will try to hunt down scot tomorrow am.
#31 |
got ahold of scot this morning. it left on old dominion fri. from our shop in bennington with a 2-3 day transit. that puts it to you wed or thurs. tracking info is on his desk and office is locked till 7am wed. will email it to you when i get to work. hope this will work for you. glen you have my # if you need anything.
#32 |
Actually they were faster than that. It came today and it's in the back of my truck right now. I'll take a look at it tonight when I get to the house. I hope the best for your grandfather and let me know how everyting goes. I really do appreciate it.
#33 |
prefect! thanks.
#34 |
Glen,
I was going through everything and I'm trying to figure out what type of throw out bearing this is. It won't seat completely flat when I slide it onto the input shaft. The hydraulic line fitting is to big in diameter and won't fit though the opening on the transmission. I thought about just making the hole bigger on the transmission but I thought I would ask you first to get some input. |
#35 |
i would give d&d a call tomorrow. it all came from them as a kit. the hole on the trans ot the black scatter shield? give me a call if you want.
#36 |
Okay cool I'll give them a holler tomorrow. Hope everything is alright with your grandfather. Thanks.
