Old 01-01-2013, 03:40 AM   #1
mexlokote
mexlokote's Avatar
Exclamation dash lights ,,, help
I recently change my gauges lights and installes some LEDs
They work great when i open the switch, they all light up right then they go off but the BRAKE light doesnt go off it stays on and i checked my brake and its ok,
It didnt used to do this before changing the lights, also when i turn my lights on the left turning signal also stays on all the time and when i put left turning signal it does flashes but after i turn it off it stays on, i dnt know if im missing a ground or something
Any help would be apreciated
Sorry about the picture , i posted via mobile
mexlokote is offline   Reply With Quote
Old 01-01-2013, 08:06 PM   #2
hatzie
Moderator
hatzie's Avatar
Re: dash lights ,,, help
The Brake light gets its' ground from a switch on the combination valve or the parking brake. Unplug the wire from the brake combination valve. Look on the left end of the frame crossrail that runs between and under the front of the engine but not quite under the radiator...
Boy that description doesn't flow well... The round white plastic plug with no wire on top in these pictures.
http://67-72chevytrucks.com/vboard/s...84&postcount=5
Check that the parking brake switch is plugged in and switching.
I'm not sure about the turn signal lamp.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 01-01-2013, 09:57 PM   #3
wilkin250r
wilkin250r's Avatar
It's also important to rule out other causes. For example, I know that my brake light doesn't turn off even when I disengage the e-brake, and it's because the spring and cable are so worn out that the pedal doesn't return all the way and therefore doesn't hit the switch. Try pulling up on the e-brake pedal, or manually press the button on the pedal to check and eliminate that as a possibility.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 01-01-2013, 10:19 PM   #4
mexlokote
mexlokote's Avatar
Thanks for ur reply i will check tomorrow
Old 01-01-2013, 11:51 PM   #5
mrolds88
You may have bumped the parking brake while working. Check your bulbs in your F/R turn signals. I've had bulbs die and the filiment lay down on the running lights and do this.
mrolds88 is offline   Reply With Quote
Old 01-01-2013, 11:53 PM   #6
mexlokote
mexlokote's Avatar
Thanks for your reply i will check tomorrow
Old 01-01-2013, 11:56 PM   #7
mooseknuckles
mooseknuckles's Avatar
your dash is in upside down....lol.
mooseknuckles is offline   Reply With Quote
Old 01-02-2013, 12:01 AM   #8
mexlokote
mexlokote's Avatar
Lol no my phone uploaded the picture upsidedown lol sorry about that
