1971 Chevy K10 with SBC 350.
Sorry for the longish post, but I wanted to write all the symptoms. Yesterday, I started my truck after it had been sitting for 2 weeks. It ran very rough and wouldn't idle. I drove it anyway thinking it needed to warm up since it had been running great and smooth. Anyway, it left an oil slick on the road and oil had sprayed from the front of the engine and seemed to be more concentrated near the fuel pump. It looked like it could have come out from below the heads or possibly at the oil pan (which has a new gasket). It is hard to tell because it was blown around from the fan. It actually smelled of gas too. When I first started it, the oil pressure gauge did jump to high and then settled back a bit. I think it has been running high for a while, but figured it was the gauge. I let it sit for a couple of hours and then started it. It ran perfect again with no oil leaks or spray and this time the oil pressure gauge had normal readings which makes me think I had very high oil pressure. The dipstick read just slightly above full (1/16") which concerned me a bit. I took off the old fuel pump which tested fine but I installed a new fuel pump anyway and again, it ran great. The PCV valve was working fine and the breather was new too. Any ideas as to what may be going on??? Thanks! |
Re: Oil Spray - Help Please
no pics?
is it still doing it? |
1969 Custom 30 wrecker
Any chance you took out a bolt in the block near the fuel pump? There is a threaded hole in that location that goes into the oil passage for the pump. If that bolt is removed, oil will leak out there.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
![]() Join Date: May 2006
Does the oil smell like gas?
Hi, thanks for the help. It is not spraying oil any more. The bolt to help hold the rod for the fuel pump is in place. I would say yes, the oil does smell like gas and it appears thin to me...no antifreeze though. I can post pics tonight. Thanks again.
Posted via Mobile Device |
Time to change the oil and filter
jaros44sr,
Yes, absolutely. Do you think the problem was the fuel pump? When I had the problem, the fuel filter was full and I noticed with the new fuel pump, the filter was not full, just a steady flow. I'm wondering if I should change out my oil pump, but I don't really want to if its not necessary. |
Gearhead
I wonder if the fuel pump diaphragm failed and allowed gas to get in the oil? I have heard this happens occasionally, have you checked the oil level to see if is high and/or what the oil looks like? If you did get fuel in the oil I wouldnt run it without an oil change, the bearings will not last long with gasoline saturated oil...
2002 Saturn SL2, My D/D 2019 Ford Fusion SE, Ecoboost - Wife's D/D 1993 Camaro Z28, A4, CAI, Cat-Back Exhaust Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD! Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644 |
#9 | |
-Nathan- 1972 GMC K2500 Suburban "The Project" 2013 GMC Sierra 1500 SLT Z71 "The Daily Driver" 2005 Ford F150 Lariat SCrew 2WD "The Daily Driver" SOLD 1995 GMC Sierra C1500 SLE "The Daily Driver"SOLD 2003 Ford Ranger Edge 2DSC 2WD Flareside "The Daily Driver/Project"SOLD |
Gearhead
I guess my only flaw with this is that oil shouldnt really be leaking out from this type of failure... but I wonder if its really two problems or one caused the other? I would check the oil level/condition, degrease the engine and surrounding area's well and then see if you can pinpoint the leak source... I also missed the post where it sounds like you have already replaced the fuel pump, did that fix the problem(s)?
#11 | |
Others will chime in if im incorrect
Thanks again everyone; I'll keep a close eye on it and let you all know if anything changes or something else happens.
Well, I put a new fuel pump in and changed the oil. The oil definitely had gas in it. I also took apart the old fuel pump to see if there was any problem with it. It looked fine and the diaphragm had no tears or punctures. I started it and it ran great, but again, it is showing high oil pressure. Soooooo, I guess I'm gonna start doing some diagnostics....starting with a leak down test. I wonder if it has bad rings or something although I recently did a compression test and all the cylinders tested fine. If the rings are worn enough to allow fuel to get by, would it still fire??? It's not missing or anything. So weird...
I bought an oil pressure tester and connected it to the same small hydraulic line that the stock fuel pressure gauge is connected to. The oil pressure was right at 50 psi at idle. When I held the revs up the pressure only went up to about 53 psi. Very strange. Does anyone know if there is a better place to connect the tester or will this be accurate? I'm hoping it is not accurate, but my gut tells me it is...
I noticed today that my pcv valve had condensation on it and i'm wondering if maybe the valve had frozen closed the day I had oil spray everywhere. That would be weird though, because I don't think it was freezing out. I'm about to just order a crate engine for Christmas! ![]() ![]() |
#15 | |
Cluster King
![]() Join Date: Nov 2012
#16 |
I'm having this same issue! Next step fuel pump and oil change for me!!
Thank you for the post! Just saved my tail!! Or, should I say motor. Posted via Mobile Device
1971 C/10 - Orange & White 2009 GMC 1500 - Lowered 3/4 22' KMC Slides |
#17 |
Update: I did a leakdown test over the holidays and I found all cylinders tested around 20%. I think that should be okay. I replaced the pcv, the fuel pump. It runs great until I shut it down and restart, then it wants to lope...so Im thinking I need to check the fuel pressure now. Glad this post may have helped.
#18 |
I just thought of something...I installed a new electronic choke and I wonder if I have it set to rich. Worth a check I guess.
