Old 01-01-2013, 11:53 AM   #1
harpo1313
harpo1313's Avatar
hei in a 250 six
Ive searched and cannot find any info for installing an hei distributor in my 250 six.Ive seen numerous pics with them on one but no info.Anyone have the details?I dont really care for the looks of them and Im familiar with the pertronic units but ive retrofit them on v8s in the past with good results,the hei that is.thanks ron
harpo1313 is offline   Reply With Quote
Old 01-01-2013, 12:01 PM   #2
ol_skool_chevy
ol_skool_chevy's Avatar
Re: hei in a 250 six
I just pulled one out of a newer 6 banger.....at pick and pull
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 01-01-2013, 12:35 PM   #3
sigshooter
sigshooter's Avatar
Any 250 or 292 HEI will work, they make a built in coil ( on top of the cap like a V8 ) and a seperate coil that is usually bolted to the side covers. Just drop it in and run a 12 volt wire from the fuse box that comes on with the key and you are good to go.
I have done countless of these change overs. You can get the HEI out of cars or trucks, novas had 6 cylinders alot.
1965 long bed ( grandpas old truck )
1964 long bed BBW Custom Cab
1966 Short stepside
1964 long bed
1965 long bed Custom Cab, factory air, V-8, powerglide
sigshooter is offline   Reply With Quote
Old 01-01-2013, 02:28 PM   #4
harpo1313
harpo1313's Avatar
That shows how much i know about 6 bangers,I thought the v6s and v8s dominated the years of the hei,never knew the straight 6s had them.thank for the info ron
Old 01-01-2013, 04:21 PM   #5
slepysal
slepysal's Avatar
you can also run a pertronix kit way easy to istall
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 01-02-2013, 07:23 PM   #6
rockdogg2020
petronixs is very easy to install, after i installed mine i just had to adjust the timing slightly. Comes with instructions
rockdogg2020 is offline   Reply With Quote
