Old 01-02-2013, 09:54 PM   #1
ABX131
ABX131's Avatar
Steering column question
Hey guys, I am normally on the 60-66 forum but my 63' has a column from a 71 that we just put in this weekend. I need a diagram of the column where it shows all the components, mainly the horn assembly. I was given the column and when I hooked up the horn wire, the horn would not shut off. I believe the PO put it together wrong and I need to know the order of assembly, it is a stock wheel. Also, does the "PRNDL23" window light up? There is a wire coming from it but no bulb. What is the wire for?
ABX131 is offline   Reply With Quote
Old 01-02-2013, 10:05 PM   #2
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: Steering column question
Tilt or no tilt? Got pics
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 01-02-2013, 10:27 PM   #3
ABX131
ABX131's Avatar
No tilt...no pics at this time but the PRNDL23 unit mounts with two screws and then ther is this second piece that comes up behind it that has a screw to hold it down. Under it is a black wire with a metal end on it that goes into the flourescent marker indicating what gear you are in. There is no room for a bulb. The other end of the wire has the same metal end like it would pug into a harness somewhere. This wire is separated from the turn signal wiring unit.
Old 01-02-2013, 10:33 PM   #4
c10monkey
c10monkey's Avatar
The wire is actually a clear plastic like fiber optics. The other end should have a bulb holder that would have gone to the back of the gauge cluster. When you turn the lights on , the glow would travel to the PRND21 to light it....
1971 Chevrolet C10 Inflation Fighter
1994 C3500 Crew Cab Dually 454
c10monkey is offline   Reply With Quote
Old 01-03-2013, 11:30 AM   #5
Ol Blue K20
C10monkey has it right, I don't think your truck has a printed circuit to use the bulb socket that went with the fiber optic cable. You may need to do some customizing, just need to get open end of cable to a light source.
Dale
Old 01-03-2013, 11:40 AM   #6
ABX131
ABX131's Avatar
How about the horn unit? Stock wheel. Have 3 pieces and need to know the order. A plastic ring, a metal cup and a thin metal disk.
Old 01-03-2013, 12:00 PM   #7
Ol Blue K20
I wish you had pics, Does the plastic ring have posts for the screws to go thru?
Dale
Old 01-03-2013, 12:02 PM   #8
ABX131
ABX131's Avatar
yes, the plastic ring has holes...I will try to post pics later of the pieces
Old 01-03-2013, 12:07 PM   #9
Ol Blue K20
OK, this is from memory so it may be wrong (been a while and I'm gettin old) first the concave plate(spring) high side up then the cup then the plastic ring with the nubs going thru both the cup and spring tighten the screws.
Dale
Old 01-03-2013, 01:00 PM   #10
Longhorn 70
Longhorn 70's Avatar
the LMC catalog is your friend.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 01-03-2013, 01:07 PM   #11
ABX131
ABX131's Avatar
That is what I need! Awesome, this site rocks. Thanks for your help.
Old 01-03-2013, 01:10 PM   #12
Ol Blue K20
After looking at the pic I reitterate I'm getting old, plastic was first oops my bad
Dale
