MOTORHEAD!
Transmission crossmember
Does anybody know of an aftermarket crossmember for a 80's era truck that will allow for 3" dual exhaust? Also, will a 63-72 crossmember, like the ones performance online makes, still fit?
Thx! Posted via Mobile Device
82 GMC High Sierra VortecPro 496 12 Bolt, 3.42's AFR 265 Holley 850 Performer RPM Air Gap Hooker 2455's TCI Turbo 400 Super Street Fighter TRRC 12 Bolt Eaton Posi/3.42 Mark Williams Axles Cal-Tracs Hoosier 30x10.5 Radial Slick Ryan Brown Performance 850 Holley Full weight long box pickup Current best- 11.28@119mph |
Re: Transmission crossmember
This is the one I used, Its technically for 62-72 trucks but the frame is the same width for 73-87 trucks.
I then fabbed up a custom 3 inch to run above the mount.
Built... Not Bought. My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=536997 |
I just re read your first post and the cross-member I used is the one from performance online!
MOTORHEAD!
K awesome!!! Just RE ordered it!!!
FlatBlack....Where did you buy you tranny crossmember? Did it bolt into the same location as the old one?
1970 C10 Short Stepper with 71/72 front clip. Last edited by BugzC10; 03-26-2013 at 09:19 AM. |
I used the same trans x-member for my 89 TBI/454 dually (just had to slightly modify it). Dual 3" exhaust fit w/no issues. My fuel filter/fuel line routing & location kind of made life difficult & wouldn't allow me to run the pipes symmetrically but other than that they fit.
That one is nice. Porterbuilt also sells one. He's a vendor here. It's the same one that comes in the dropmember kit.
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
I have 3 of PB's trans x-members. I like the way the POL/ECE x-members tie the top & bottom of the frame rail together similar to OE vs PB's or other similar aftermarket units that just bolt to the side of the frame. So the PB units are leaning against a corner in the shop despite the fact they are an easier install.
I bought it from performance online, it lined up nicely with two of the already existing holes on the frame but i did have to cut/drill my other holes.
#10 | |
