![]() Join Date: Dec 2012
92 c1500 anti lock brake swap
Is it possible or not to take the anti lock brakes from say a 92 c1500 and put that on a square body? ..has anyone tried it...or are there too many conflicts?
thanks for any thoughts or help Ray |
Re: 92 c1500 anti lock brake swap
Why would you want to make it harder to stop?
A good addition would be a dodge 8-3/4 axle that has anti lock breaks on just the rear axle which is where it matter most. There's a reluctor ring they use that can be adapted to most dodge axles. I belive mopar mag did this to a early Dakota. Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
anything's possible but why would you want to? IMO ABS wouldn't offer you anything but headaches and hassle.
If you are serious the Kelsey-Hayes RWAL would be easiest, it would just need a signal from a vss. you can use one of those adapters on the speedo cable. it might keep the rear from locking up. Maybe. |
Abs would be an amazing addon for these sleds
Posted via Mobile Device |
#5 | |
Personally, I have never been in a position where ABS provided me any additional control or stability. I've rolled through many an intersection with ABS working as hard as it could to keep me from sliding when a sideways slide and a bump against the curb before the intersection would have been preferred. Others may have had other experiences, but IMO ABS is a joke. |
Abs is a for the most part a controlled stop and in almost all cases a faster stop. Not going into how they work but know they are awesome.
The 88-98 trucks are RWAL, the rear brake line pressure is modulated based on seeing front to rear speed differences. Thre is no antilock on the front. My personal experience in driving one 215.000 miles was that it was no help on ice, dangerous in the rain, and would go off when not needed when stopping on bumpy roads. In my 10 years of driving it in Michigan, on all types of raods and all types of conditions, it never once helped me stop.
If you wish to do it the best way is to swap the entire rear with new brackets and offset wheels and use the 88-up lowering spindle swap documented in the Suspension area. Then you essentially have a 1988-up runnng gear. But as pointed out above there are more effective ways to do it and probaby at less cost.
1987 2 ton ![]() 1982 250/TH350 beater in progressDad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrappingPlus a mess o' tractors |
Moderator
![]() Join Date: Oct 2008
I unplugged the Maxi-Fuse and the dash warning light from the ABS on my T400 truck.
IMHO it's a poorly implemented system. If I drove over a small bump while braking the ABS kicked in wildly extending the stopping distance. I'd look elsewhere for braking improvements. This aint it. ![]() Replace all three flex lines, completely flush the fluid with fresh clean DOT4 fluid, and adjust the takeup wheel on the drum brakes. It's a good on-the-cheap weekend "upgrade". You'll feel the difference immediately. Wider drum brakes from a heavy duty model in your tonnage will make a difference on-the-cheap. More $... Hydroboost from a K30 or diesel model. Rear disc brake upgrade that includes upgrading to a rear-disc combination valve and rear-disc master cylinder.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
Don't even think about it. Sure, ABS does provide some advantages otherwise it wouldn't be standard equipment on all cars today, but for some system from a newer vehicle cobbled onto an older vehicle with no adjustments or tuning, it just seems like a recipe for failure.
Furthermore, ABS is geared toward the average person, think Ralph Nader for example, who freaks out and slams their foot to the floor and then files a lawsuit against the car manufacturer. Idiot proof. But do think about this. http://www.73-87.com/7387garage/chas...ension/lbs.htm
1977 GMC Sierra Grande |
And is good for your gf but not for you a I say. It's been proven a non and car can stop yards sooner than a and equipped car WHEN the drive know how to modulate brakes rather than just skidding to a stop. Had a 98s10 with antilock you slanes on the brakes in the rain and it dance up and down side to side. My gfs BMW when you hit the brakes over a seer drain its so sensitive that the one wheel hops and skips for three feet before it stops
I seen a early camaro they put a corvette abs on it,It looked like a nightmare of a swap to me.First the doner truck has to weight about the same as your truck does now.You need the whole system from spindles to rear end.
thanks for the responses....I think Ill just get some wilwood replacement d52's and vented drilled and vented rotors
| Bookmarks |
