Old 12-23-2012, 05:18 PM   #1
McNutty
McNutty's Avatar
Dually guys get in here!
Might be picking up a 82 single cab dually shortbed 454 th 400.
The body is rough but seems the running gear is solid. Thinking of just slamming it and stick steel black wheels, shoot it flat black and tint the windows and make a fun cruiser.
Is ther a set of steel 17'' dually wheels? Can I make the rear from dually and just put one large wheel and tire on rear? Is it as easy to lower as any other 73-87 chevy?
But I wanna make this fun, maybe fast, low and loud!
McNutty is offline   Reply With Quote
Old 12-23-2012, 09:31 PM   #2
J Knight
J Knight's Avatar
Re: Dually guys get in here!
Sounds cool, you sgould be able to find a set of 19.5 steelies from a motor home.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 12-23-2012, 10:54 PM   #3
ghettoluxury
ghettoluxury's Avatar
Yes you can get super wide rear rims whatever offset needed in an 8 Lug pattern. Lowering a Dually is as simple as any other 73-87. The only major differance is the rear spring width is narrower than the 1/2 tons, so you can't use the pre made spring hangers.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 12-24-2012, 03:46 AM   #4
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
17's would be 2007-2010 gmc chevys.
If it aint square, I don't care.
84 C35 CC Dually Project log...
http://67-72chevytrucks.com/vboard/s...d.php?t=414892
1tonchevy is offline   Reply With Quote
Old 12-24-2012, 06:47 AM   #5
bk2life
or you can use 22 or 24 inch semi wheels.
you can slam it to the ground, add a big motor and go cruisin..
bk2life is offline   Reply With Quote
Old 12-24-2012, 08:00 AM   #6
BigBlocksRule
^ and spend about 5 times as much on the wheels and tires as you're paying for the truck
I'm building a dually and will have to have custom 16x10s made, I want to keep it dually rather than running a super single.
BigBlocksRule is offline   Reply With Quote
Old 12-24-2012, 12:57 PM   #7
jitteryguy
GoatLube Experss
jitteryguy's Avatar
only 3 times more for the wheels than the truck, but worth it.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 12-24-2012, 06:45 PM   #8
McNutty
McNutty's Avatar
Yeah i do not wanna spend a ton of money of wheels. I want steel wheels so i can paint them or aluminum if they are cheap enough. Dont the 19.5's need milled down or something? might just use a stock steel wheel on front and find the big fat wheels i want for the rear!
Old 12-24-2012, 07:15 PM   #9
McNutty
McNutty's Avatar
Found my wheels, 15x10 front and 15x14 rear matte black steel wheels!
Old 12-24-2012, 07:21 PM   #10
jitteryguy
GoatLube Experss
jitteryguy's Avatar
that will look good
'85 1/2 ton CCSB
'92 S10 350/350
Old 12-24-2012, 07:24 PM   #11
hyatt
Here is my 99 with only 24k miles
1946 car hauler
1948 surburban
1937 chevy sedan
1940 olds sedan (project)
1967 ss396 chevelle
1999 dually crewcab(24000 miles)
hyatt is offline   Reply With Quote
Old 12-24-2012, 07:41 PM   #12
McNutty
McNutty's Avatar
With those wheels dont you have to get wheel adapters or something?
Old 12-24-2012, 07:52 PM   #13
63chevyll
gets board easy.......
63chevyll's Avatar
Wow. How did you ever find that truck
63chevyll is offline   Reply With Quote
Old 12-24-2012, 08:02 PM   #14
hyatt
I bought it new
1946 car hauler
1948 surburban
1937 chevy sedan
1967 ss396 chevelle
Old 12-24-2012, 08:04 PM   #15
jitteryguy
GoatLube Experss
jitteryguy's Avatar
yes, I have 8 to 10 lug adapter's on it.
'85 1/2 ton CCSB
'92 S10 350/350
Old 01-04-2013, 06:34 PM   #16
63chevyll
63chevyll's Avatar
I bought it new
fair enough..HA,
cool
Old 01-04-2013, 06:38 PM   #17
Can't kech me
Can't kech me's Avatar
anyone running a super single in the rear? i've always wanted to see em on a lowered square
"As I walk through the valley of rice i fear no honda, for i have torque!"
Can't kech me is offline   Reply With Quote
