05-24-2011, 02:25 PM | #1 |
1972 Cheyenne Parchment Door Panels
Clean set of 1972 Cheyenne parchment door panels. Mounting tabs are excellent, no extra holes or major damage anywhere. These are driver quality panels or could be dyed to 100% color for show. There is light yellowing.
$95 shipped. |
05-24-2011, 02:40 PM | #2 |
Re: 1972 Cheyenne Parchment Door Panels
Is the wood just a decal? Mine are the same but white
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently. http://67-72chevytrucks.com/vboard/s...d.php?t=451950 1971 c10 step 250 3 OTT 1969 c30 TOW-MATER. 307 4 speed, holmes 440 body. http://67-72chevytrucks.com/vboard/s...d.php?t=451082 2006 CTS-V LS2 6spd. Last edited by no moa; 05-24-2011 at 02:41 PM. |
05-24-2011, 04:39 PM | #3 |
VA72C10
The wood is a metal panel that gm printed the woodgrain onto the metal.
Looking for a 67-72 swb or blazer project in or around VA. |
05-24-2011, 06:51 PM | #4 |
So is it glued or screwed on?
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently. http://67-72chevytrucks.com/vboard/s...d.php?t=451950 1971 c10 step 250 3 OTT 1969 c30 TOW-MATER. 307 4 speed, holmes 440 body. http://67-72chevytrucks.com/vboard/s...d.php?t=451082 2006 CTS-V LS2 6spd. |
05-24-2011, 06:55 PM | #5 |
the woodgrain is on and aluminum insert that is held in place by the stainless trim. the woodgrain is the upgrade from custom deluxe to cheyenne and so forth.
05-24-2011, 07:26 PM | #6 |
E.H.F.D Engine #2
Question about these... Is the scroll still underneath the woodgrain panel? I ask because i'm not sure yet whether i will be restoring my truck to a Custom/10 or a Cheyenne. If there is the factory scroll work under that panel, I'll take them.
-NICK '72 K10 SWB Fleetside. Avocado Highlander 350-4speed-NP205 Frame Off Re-Creation '89 GMC V3500 C/C Flatbed Plow Truck 454/SM465/Np205 '15 Chevy 2500HD CCSB High Country Duramax '22 Tahoe Premier Duramax |
05-24-2011, 07:36 PM | #7 | |
Ray
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White |
05-26-2011, 10:05 AM | #8 |
E.H.F.D Engine #2
cheyenne402 - if you can tell from the back if they have the scroll (without having to take the wood panel off) and LMK, that would be great. Also send me some payment info.
-NICK '72 K10 SWB Fleetside. Avocado Highlander 350-4speed-NP205 Frame Off Re-Creation '89 GMC V3500 C/C Flatbed Plow Truck 454/SM465/Np205 '15 Chevy 2500HD CCSB High Country Duramax '22 Tahoe Premier Duramax Last edited by yfs200p; 05-26-2011 at 10:06 AM. |
05-26-2011, 10:57 AM | #9 |
For the parchment panels if you very lightly media blast them all of the yellow chalking will come off. Your panel will be more of a flat color but will otherwise look really nice and almost new. The areas where the chalking is scratched through to good plastic will also be gone. I've done it a couple of times with really good results and you won't have to worry about paint adhesion. This kind of plastic is very difficult to get good adhesion to. You'll have to remove the inserts or mask them really weil. I'd remove them.
Saskatoon, Saskatchewan Canada |
05-26-2011, 06:51 PM | #10 |
Anyone want these then? TTT
05-26-2011, 09:11 PM | #11 |
E.H.F.D Engine #2
?? I said I'd take them if you could just let me know whats underneath the woodgrain. Sorry if that was unclear
05-27-2011, 01:15 PM | #12 | |
Yes there is scrollwork under the woodgrain as was mentioned. All the original doorpanels for the Cheyennes had scrollwork under them. Thanks. |
05-27-2011, 07:10 PM | #13 |
E.H.F.D Engine #2
Payment sent.
06-04-2011, 12:21 PM | #14 |
If payment is not received I will take them.
Posted via Mobile Device |
06-05-2011, 05:26 PM | #15 |
Payment received. Sold.
01-04-2013, 10:35 PM | #16 |
Thanks Stingray for the tip on media blasting, it worked perfect. guy who did it for me also suggested I clear coat them with semigloss since the surface is pourous and will stain/absorb dirt without protection.
