Old 01-03-2013, 11:58 PM   #1
Samhecker
exhaust system
i've got a 1985 chevy k10. It has a 350 in it and i was wondering what headers to use, along with what size pipe i should use and if true duels or a x pipe would be better for torque/hp gains. Thanks
Samhecker is offline   Reply With Quote
Old 01-04-2013, 12:11 AM   #2
Pyrotechnic
Pyrotechnic's Avatar
Re: exhaust system
Welcome to the board.
For headers, I recommend Hedman Elite series. I can't speak for the 4x4 version, but the 2WD version had a superior fit and finish to the typical $100 headers. The cheap ones will leak, fry plug wires, and just don't fit the truck well. This is not a place you want to cheap out, or you will end up hating the headers and be begging for your manifolds back.
For a 350 with a dual exhaust I recommend 2.25 inch pipe. As far as separate unconnected dual pipes, H pipe, and X pipe a lot of is it about sound and how much you want to spend.
Personally, I would run unconnected dual pipes, but that is just me. I like the stereo sound you get from having the sides separate.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 01-04-2013, 12:26 AM   #3
xole
xole's Avatar
Re: exhaust system
+1
I am putting Hedman headers and Dynamax 2.25 pipes on my 86 K10 hopefully this weekend if I get far enough along with the engine swap.
'86 Chevy K10 SWB Custom Deluxe 4x4
'94 Chevy Corvette
'07 Ford Mustang
'08 Lexus LS 460
xole is offline   Reply With Quote
Old 01-04-2013, 12:34 AM   #4
Samhecker
Re: exhaust system
thanks as soon as i save the money ill see about investing into the headers and ill probably end up doing true duel pipes
Old 01-04-2013, 03:02 AM   #5
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: exhaust system
Pypes makes universal xpipes and completed truck systems. Check them out on summit
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 01-04-2013, 08:29 AM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
Re: exhaust system
I have duals on both trucks
79-305-2B-4X2 i did 2.25,custom,manifolds H pipe,to flowmasters
78-350-4X4-walker stock replacements ,manifolds to cherry bombs
love em both
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 01-04-2013, 08:35 AM   #7
88Jimmy4x4
88Jimmy4x4's Avatar
Re: exhaust system
is your 350 stock or modified?
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 01-04-2013, 10:59 PM   #8
Samhecker
Re: exhaust system
its basically stock
Old 01-05-2013, 01:54 AM   #9
xole
xole's Avatar
Re: exhaust system
I think the Pypes system is for 2WD only.
'94 Chevy Corvette
'07 Ford Mustang
'08 Lexus LS 460
