01-04-2013, 02:06 PM | #1 |
Hey, what is this thing on my steering column?
Look in the lower left part of this picture... What is that lever/"thing"?
It appears to be broken off. Truck has original floor-shifted 4 speed manual trans. Also... I can start the truck without the key... Just turn the ignition and it starts... Dont know if there is any relation or not... Is this not the original column? Just curious... I have a new column with shifter that I will use when my 700R4 goes in... |
01-04-2013, 02:09 PM | #2 |
MOTORHEAD!
Re: Hey, what is this thing on my steering column?
I think its a ignition cylinder lock release.. Common on most manual transmission vehicles, but I dont know their purpose!
82 GMC High Sierra VortecPro 496 12 Bolt, 3.42's AFR 265 Holley 850 Performer RPM Air Gap Hooker 2455's TCI Turbo 400 Super Street Fighter TRRC 12 Bolt Eaton Posi Mark Williams Axles Cal-Tracs Hoosier 30x10.5 Radial Slick Full weight long box pickup Current best- 11.33@117mph |
01-04-2013, 02:09 PM | #3 |
Are you talking about the little lever next to the ignition switch?
That is the key lock for manual trans, you should have to push it down when turning off the truck. Unless its broken, that is. |
01-04-2013, 02:15 PM | #4 |
That's the ignition lock for taking the key out. Just press down the lever and turn the key in the off direction to take it out. Only for manual transmission trucks?
MY6 Stepside |
01-04-2013, 02:41 PM | #5 |
OK, that makes sense all. Mine is busted, hence my ability to start truck without a key. Thanks!
1972 GMC Sierra Grande (current truck) 1980 Chevy Stepside (gone) 1987 Chevy Blazer (gone) 1972 Chevelle SS Convertible (gone) 1973 Chevy Corvette (gone) 1967 Chevy Camaro (STOLEN!) |
01-04-2013, 04:14 PM | #6 |
on my 81 man.4 speed u have to push down that lever while turing back your key ortherwise it wont let the ign. key out
01-04-2013, 04:49 PM | #7 |
MOTORHEAD!
Cam somebody explain why this exists? It's obviously a safety reason??
01-04-2013, 05:05 PM | #8 |
What year did they start having those? My 78 does not have that.
01-04-2013, 06:37 PM | #9 |
78K & 79C Jimmys
In an Auto the key won't come out till it's "P" and the then it locks left to right
this keeps the key fwd ,not locking up the wheel tumblers/cylinders wear out,common
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
01-04-2013, 06:42 PM | #10 |
im pretty sure its a safety reason plain and simple... but it quickly get to be a reflex so ....instead of beeing a safety feature you look more weird shuting down other poeples car.
01-04-2013, 07:36 PM | #11 |
Dino burner
I don't know exactly when they began using them, but my brother's 1980 K20 GMC Sierra Grande has that style of lock column. It's a 350 small block engine and 4-speed manual transmission set up, stock from the factory.
01-04-2013, 08:00 PM | #12 |
My 86 gmc has it, and so does my 83 s-10. both standard trans. My 84 and 85 chevys dont have it and they're both automatics. I was never sure what they were for either.. cool.
01-04-2013, 09:20 PM | #13 |
All manual GM columns have a lever or a button that you have to press to get the key out. It does the same as the cable unlock in park on an automatic. It's a safety to keep you from turning the key back and having the steering lock up under driving.
01-04-2013, 11:51 PM | #14 |
My 78 manual column doesn't.
01-05-2013, 01:50 AM | #15 |
My trucks' a '78 and it has it. The wheel doesn't actually lock but it's there
1981 K10 Scottsdale
305 ci | TH350 | NP208 | 60k miles |
01-05-2013, 11:54 AM | #16 |
GM ignition switches are known to wear out. In high school I had a couple of friends with 80's FWD GM cars that could be started without the key.
Best fix is to rebuild the column with a new lock cylinder and replace other worn parts. Second best fix is to harvest a good functioning column with key from your local auto salvage. |
01-05-2013, 12:37 PM | #17 |
My 81 3/4 with 3OTT does not have it, nore does my 77.
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors |
01-05-2013, 08:08 PM | #18 |
do you have to put it in reverse to get the key out? some manuals had that (not sure about trucks, talking about cars)
01-06-2013, 08:55 AM | #19 |
I had a ´72 Cadillac Sedan deVille wich had a lever like that for the steering column to slide in and out! Only difference was that it sat on top not on the side of the column!
Volker
My little US vehicle parts business: http://www.thegearheaddepot.com/ Come have a look! ´81 GMC C 10, Spanish Red |
01-06-2013, 09:57 AM | #20 |
