Old 01-06-2013, 10:50 AM   #26
Re: Check out this original 69/70 grille I picked up for $37!
How's your '69 insert? Why not use that with this grille?
Old 01-06-2013, 11:09 AM   #27
bollybib
bollybib's Avatar
wow you lucked out on this find !
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline   Reply With Quote
Old 01-06-2013, 11:39 AM   #28
CC69Rat
CC69Rat's Avatar
Subscribed .. tell me more on the Easy Off oven cleaner. Would it clean up my upper belt line trim as well? Does it just strip off the old anodizing so you can polish the underlying aluminum (or whatever .. ? ) Then re-paint what needs to be black ?
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 01-06-2013, 12:43 PM   #29
Mister-B
My '69 insert does have one of the egg crate squares that is cracked. Not a big deal. Nobody but me would notice. The biggest thing, though is that I think the insert is held on by rivets, which means I'd need to drill out the rivets on both sets of grills, and then buy some new rivet/screws from brothers. If I just replace the whole thing and leave it in tact, it'll be much easier. That's how I got the grill off the truck at the junk yard
Mister-B is offline   Reply With Quote
Old 01-06-2013, 12:45 PM   #30
Mister-B
That's what I've heard, but you better be real careful, or it'll eat the paint off your truck.
I just bought some of the oven cleaner last night, so I plan to work on this today
Old 01-06-2013, 06:24 PM   #31
Mister-B
Turns out I was wrong about something. The inner grill does not connect with rivets. It connects with bolts, so I was easily able to remove it from my new grille, which is making the restoration process much easier. Spraying oven cleaner would have been really tough, if I'd have had to keep it off the plastic insert.
I got it all apart, and sprayed the metal outer grill with oven cleaner, and it's sitting. I'll probably use my '69 inner grill, because upon closer inspection, the '69 inner grill is in slightly better shape
Old 01-07-2013, 12:18 AM   #32
Mister-B
Ok, here's an update. I put the oven cleaner on and let it sit for an hour, then removed it with a rag and a bucket of water. I honestly don't know if the oven cleaner helped, but the steps after that sure did.
I sanded the entire thing down with a medium grit sanding block. Then sanded it with 400 grit paper. Then sanded it with 600 grit. I then took some Mothers metal rubbing compound and worked it in with a rag, and completed wiping it down with a cean rag. I then connected an attachment to my DeWalt drill on high speed that's basically a disc with a sheepskin looking cover on it. I applied more Mothers to the disc, and buffed it in to the entire grille at high speed. Completed the step with a clean rag wipe down. Final step was some Eagle One metal shiner that I rubbed in, followed by a rub down by a clean rag. It's definitely more shiny. Next step...mask and paint the black areas
Old 01-07-2013, 08:26 AM   #33
Square_78
Square_78's Avatar
Originally Posted by Mister-B View Post
Awesome. Thanks for the tip. Do you scrub it with a scotch brite pad or something?
I did use a green scuffy pad just because I wanted that brushed texture on the aluminum anyways. If you are going for a polished look, just scrub lightly so you dont scratch it too much. You wont need much force anyways. The anodizing just bubbles right up after about 30 seconds and it wipes right off.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 01-07-2013, 09:24 AM   #34
teeitup
Just like to part out trucks!!
teeitup's Avatar
Looks great
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
Old 01-07-2013, 08:04 PM   #35
Mister-B
I got the black areas and letters painted!
For the letters, I used a small flat brush and some black paint. For the lines and areas around the headlight, I masked and sprayed it.
Old 01-07-2013, 08:49 PM   #36
69GWC
Looking good.
69GWC is offline   Reply With Quote
Old 01-07-2013, 09:06 PM   #37
Mister-B
Originally Posted by 69GWC View Post
Looking good.
Thanks, man. It's been a lot of work, but sure worth it. It's crazy how expensive an original type grill with the Chevrolet letters costs.
Old 01-07-2013, 09:10 PM   #38
69GWC
Oh yeah thats why mine has a repop in it with no name on it...lol
I have a good original stock 70 as well that I am keeping for a spare.
Old 01-07-2013, 09:13 PM   #39
Mister-B
I noticed LMC sells an adhesive letter kit for not much, that spells out CHEVROLET
Old 01-07-2013, 09:17 PM   #40
69GWC
I do have that letter kit but I think it looks cheesy myself I kinda like the smooth look it has. If it does not have the correct stamping.
Old 01-07-2013, 10:18 PM   #41
Mister-B
Yeah, you're probably right
Old 01-09-2013, 08:00 PM   #42
Mister-B
I got the insert painted to like factory specs (black edges, metallic silver squares), and then got it installed on the truck. Quite the difference! Of course now I need a new front bumper and hood emblem more than ever lol
By the way, here's the before shot
And the after one more time
Old 01-09-2013, 09:11 PM   #43
lolife99
67-72 parts collector,…
lolife99's Avatar
Excellent work!
Keith
Convert to disc brakes.
Old 01-09-2013, 09:27 PM   #44
5-0 C/10
Posted via Mobile DeviceLooking good man!!!!
5-0 C/10 is offline   Reply With Quote
Old 01-09-2013, 09:39 PM   #45
Mister-B
Excellent work!
Thanks, man. You know your stuff about these grilles too
Old 01-10-2013, 12:20 AM   #46
Square_78
Square_78's Avatar
I'd definately remove the grill first. Oven cleaner will destroy your paint almost instantly.
#teamlongbed
Old 01-17-2013, 07:15 PM   #47
Madtat
Madtat's Avatar
Nice!!!!
Madtat is offline   Reply With Quote
Old 01-17-2013, 08:02 PM   #48
sprint_9
sprint_9's Avatar
Hard to believe that came out of a junk yard, great work.
Inspired by your success I took to my local yard today but the C10's were pretty well picked over, what was left was pretty much useless. Still fun to look around though.
sprint_9 is offline   Reply With Quote
Old 01-17-2013, 08:03 PM   #49
shawno72
C/10 junkie
shawno72's Avatar
Very nice!! Super job!!
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 01-17-2013, 08:16 PM   #50
Mister-B
Thanks guys. I'm pleased with how it came together. You just never know with junk yards. It helps if the truck has been there for less than a week. Sometimes I find things I didn't even know I wanted, but when I realize its an original part that's in better shape than a particular part I have, and it's like 5 bucks, I'm going for it. Personally, though I'd stay away from stock washer motors, heater blowers, etc. You're talking about a 45 year old part that needs to function, and is likely ready to bite the dust
