![]() Join Date: Oct 2009
1971-72 GMC Fender GM or Aftermarket?
I picked up a fender last weekend that is from a 71-72 GMC. It is in Very good condition for Indiana sheet metal. What I would like o know is how can I tell if it is original GM sheet metal or if it is an aftermarket fender? Is there any good way to tell? Thanks for any help.
Note: All parts I have for sale are also for sale locally. I currently own: 1940 Chevy Fire truck (project), 1946 Chevy truck (project), 1946 Chevy 1 Ton pick up, 1953 Chevy school bus (storage area), 1968 Chevy C10 (I have drove for 26 years), 1994 Chevy C2500 (daily driver), 2005 GMC crew cab K2500 (parts hauler) and more trucks for parts. |
Re: 1971-72 GMC Fender GM or Aftermarket?
The guy I got it from said he painted it but there does look to de some kind or repair in the inside of the cup and a few emblem/ molding holes that have been filled.
Try putting it on. If it fits it's a GM
Thanks special-K
I was thinking I seen where the originals have 3 triangles up in front along the hood edge. They would be visable is picture 3 but this one does not have them. I looked at my 68 Chevy and it does have them but I have some other fenders and 1 that I know is an original from a GMC and it does not have the triangles either so I thought maybe that was a 68 only thing.
That's what I couldn't remember,the three triangles. I was going to take pictures of a GMC fender I have,but here's a '67 picture I already had.
I also hd these pictures of a 69 or 70 GMC fender...just in case anything changed:
I can not tell by those pictures if the GMC has the triangles or not. Thanks for the pictures and I will look more when I get home from work tonight. Thanks
Petroleum User
I have two feenders that Im pretty sure are '68 chevy and they have the three triangle dimples. The fenders on my '71 GMC dont have the dimples/bends.
![]() 1971 GMC Sierra Grande 2WD 1/2 ton, 350/400 auto 2008 Chevy Silverado 2WD 1/2 ton LT1 5.3L auto |
The second picture shows the dimples and all the others give you lots of other areas to compare. The dimples are just the most obvious telltales at a glance. I'm pretty sure yours aren't OEM.
#10 | |
Yes it does on the 67 fender which is just like my 68 fender I described earlier. What I was meaning was on the second fender you had pictures of and said it was a 69-70 GMC. I could not see that area on it. Thanks for the pictures and I will compare them tonight. Thanks again
Alright,I see now. I showed those just because I had the close ups already and other details could be compared. But,I just went and looked at my all original '72 GMC and also a 100% original '72 Jimmy fender I have and there are no dimples. I never realized this before. Another break-through 67-72chevytrucks.com moment!
#12 | ||
All the things I have learned from this sight is just one of the reasons that this site is so great.
Moderator
![]() Join Date: May 2007
The triangles have been discussed before. I believe they were only on 67-68 fenders, iirc. None of the 69-up trucks I have seen have them present.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Thanks Leddzepp.
Well I looked the fender over and compared it to the pictures and a GMC fender I have off and I found one difference so I thought I found my answer and then I went out and looked at a 69 GMC I have and found it looks the same as this fender. On the front edge of this fender, there are holes where the 67-68 headlight bezel would mount. The GMC fender I have in the barn does not have any holes but when I went out and looked at the 69 GMC, it does have the holes like the one I bought. Everything I can find different, I can prove it wrong also. Maybe you were right in the beginning Special-K, the only way I will know is to install it and see how it fits.
#15 |
The '67 I showed has the holes. I guess the 69/70 doesn't show that area. I have that '72 fender to check and also another pair of '67 GMC fenders I can check out.
#16 |
Well thelonerife (Chuck) was here today so I had him look the fender over and he thinks it is GM also. So my hope is still alive and good that this is GM and not aftermarket.
#17 |
this is a great topic because I too recently bought 2 fenders and cant for the life of me tell if they are oem or not. where are these 'triangles' that you guys are talkin about? also, I wonder if they had them in 67-69 and not after 70 due to better stamping techniques? just a thought.
#18 |
A large majority of the time an aftermarket fender or any body panel with have a stamp of the aftermarket companies logo. Most of the time on these fenders they're about half way up the top edge of the fender on the inside step were the hood sits.
1968 chevy lwb, getting ready to join forces with the 70 gmc 1970 gmc swb, getting ready to be a 68 chevy swb 1971 gmc lwb 2500 2wd Sierra Grande 1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins |
#19 |
![]() Join Date: Jul 2012
One more thing i noticed with an aftermarket fender that i have here, on the inside of it where it has the welded on "nuts" the GM fender had square nuts, the aftermarket had standard hex. Not sure if this is true to all of them or not. My aftermarket fender is stamped "Gordon". Had a big dent in the front, so i am using it to patch a rust hole in a GM fender.
"Rusty" 1972 K20 Cheyenne Super, 496, A/C, Tilt, Tach, Buckets, 4l80e/NP205, 4" Rancho Lift, 35" BFG AT "Ramp Truck" 1972 C30 Ramp Truck 350, Air Bags, Factory A/C. "1968" C10 Shortbed project |
#20 |
#21 | |||
You guys have eagle eyes. It took me a little while to even find 443. LOL
#22 | |
