Motor mount question
Hey guys, I got a 67 with a 250. I am wanting to put in a 350 but the motor mounts on the 250 dont look like they will fit the 350? LMC shows the 250 and the small blocks use the same mounts? Can anyone help on this? Thanks.
Posted via Mobile Device |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: Motor mount question
They bolt on. The three bolt pattern is the same between the 6 cylinder mount brackets and the small block V8 engine block holes.
You just use the rubber part, not the steel bracket that goes between the six cylinder block and the rubber part. |
![]() Join Date: Aug 2008
I believe you need sb frame stands though...
