Old 01-06-2013, 08:24 PM   #1
rsmarr1982
rsmarr1982's Avatar
tow hook info
i got these tow hooks off a 72 k20 frame that was trashed. i wanna use them on my 71 k20 but the holes on the hooks dont line up with the two holes on my 71 frame. are these hooks factory? did they use diffrent hooks through the years?
1969 chevy c10 lwb stepside 250 6 3 ott
1971 chevy c10 lwb 250 6 with power steering 3 ott
1972 chevy k20 4x4 350/TH350 automatic
1978 chevy Malibu 4dr 305 2bbl (all original)
1979 chevy k10 Scottsdale 350/th350 full-time 4wd(daily driver)
rsmarr1982 is offline   Reply With Quote
Old 01-06-2013, 08:31 PM   #2
71swb4x4
71swb4x4's Avatar
Re: tow hook info
Those were used in 1972 only. They sell for about $100 more that the 69-72 style hooks. The bolt holes on the two styles are the same so you will have to drill either way.
The "extreme bend" tow hooks started sometime in 1972. The 69-72 style was used a little ways in the 72 production run.
I doubt anyone would notice if you use that style, and if they did it wouldn't matter.
Edit: check out this thread. It has 69-72 style hooks pictured, but also mentions the 72 style mounts differently than the 69-72 style. http://67-72chevytrucks.com/vboard/s...d.php?t=305926
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 01-06-2013, 08:37 PM   #3
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: tow hook info
Those are 1972 specific tow hooks the "extreme bend" hooks - a one year only deal. These bend in the same direction (i.e, one sided). The correct hooks for a 71 are the 69-72 type: these bend in opposing directions (i.e., there is a RH and a LH hook). In at least 72 the 4wd frames were all drilled for hooks by GM whether or not the truck was so equipped. I have a spare set of 69-72 hooks to trade!
Old 01-06-2013, 09:18 PM   #4
rsmarr1982
rsmarr1982's Avatar
Re: tow hook info
are they worth so much more just because they are 72 only? i think ones going away from each other would look better.
Old 01-06-2013, 09:59 PM   #5
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: tow hook info
I believe the 72's command more $$ because they are a one year off option and supply is limited. Some guys do prefer the more balanced look of the 69-72 hooks: I have a set of 69-72 on my K10 now for that reason but will put the 72 only style on my K20 resto.
Here are some comparison pics I saved that were posted by a board member in a thread I wasn't able to find on a quick search so can't give credit where do.
Old 01-07-2013, 09:29 AM   #6
jeremy zander
jeremy zander's Avatar
Re: tow hook info
I will trade you the correct style for your truck(69-71) if you want to ..PM me if you like....
WTB 1972 CHEVY 3/4 4X4
1971 chevy c30 4x4 NAPCO (project)
1972 chevy 3/4 4x4 350/350 4spd, tach, tow hooks,radio delete,heat delete,hubcaps,lockers
1972 chevy 3/4 4x4 383/350 dads original farm truck tilt,tach,tow hooks,hubcaps,radio delete,heat delete
2006 chevy LBZ crew cab duramax,4 inch,beadlocks
2015 chevy tahoe Z71 my fifth one,love em
2016 chevy 2500HD Z71 LTZ duramax midnite
2018 chevy suburban Z71 midnite
jeremy zander is offline   Reply With Quote
Old 01-09-2013, 07:30 PM   #7
jeremy zander
Re: tow hook info
This is what I have ...
Old 01-09-2013, 11:01 PM   #8
Joesjunk
Joesjunk's Avatar
Re: tow hook info
71 frames were not drilled unless hooks were ordered, I added hooks to my 71 and had to drill the holes
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
Old 01-09-2013, 11:07 PM   #9
69GWC
Re: tow hook info
Does anyone have good pix of these installed?
69GWC is offline   Reply With Quote
Old 01-09-2013, 11:16 PM   #10
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: tow hook info
Not my pics...
Old 01-09-2013, 11:21 PM   #11
69GWC
Re: tow hook info
Cool thanks, Have to see if I can find a set of those.
Old 01-09-2013, 11:25 PM   #12
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: tow hook info
You bet. Maybe Jeremy will part with one of his sets?
Old 01-10-2013, 05:06 AM   #13
birdistheword
birdistheword's Avatar
Re: tow hook info
Wow really glad I found this. I happen to have a set of 72 only hooks I snatched off a beat up Jimmy and was saving them for a worthy truck. I have a 72 K10 but I'm not sure the holes lined up good for them.
Erik
1969 Chevy K20 6.0L/4L80E/NP205
1971 Chevy C30 Cheyenne Longhorn 454/TH400
1971 GMC C3500 becoming a K3500 dually
birdistheword is offline   Reply With Quote
Old 02-03-2013, 12:30 AM   #14
1970 CST STEP
Re: tow hook info
Would u be willing to part with a set? Need a set for 1970. Thanks.
1967 SWB (small window) original
1970 4x4 STEP
1970 CST SWB FLEET
1972 SWB FLEET ORIGINAL
1970 CST STEP is offline   Reply With Quote
Old 02-13-2013, 11:18 PM   #15
jaywashburn
Re: tow hook info
Hello. found this thread to be quite interesting. I have a pair of 67-68 tow hooks (based on Deadhead NM's tow hook layout). I have yet to install them on my '72 K 1/2 ton Suburban. Opon initial inspection it does'nt look like they want to fit my frame. My frame came with the tow hook holes predrilled. The tow hook holes do line up with my frame but it seems like the bumper is slightly in the way. Should these tow hooks fit my truck ? If not would someone want to do a trade for the other style. Mine have the extreme curl where the two holes are located. It seems like the other ones that have a straighter neck (where mounting holes are) would fit.
Any thoughts.
Thanks,
J
jaywashburn is offline   Reply With Quote
Old 02-13-2013, 11:29 PM   #16
too much stuff
Roadtrip!
too much stuff's Avatar
Re: tow hook info
jaywashburn, no they won't fit without modification. The ones you have actually started in 60 and went to 68 i believe.
67 gmc custom lwb dakota truck. Sold...And bought back... And sold again...
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 02-14-2013, 02:51 PM   #17
jaywashburn
Re: tow hook info
"Toomuchstuff". Thanks for the reply. I guess I will clean mine up & try & sell them.
