#26 |
Just here to tinker
![]() Join Date: Jun 2008
Re: 1/2dozen Burban
Just beautiful man! Well done!
Forgive me if I missed it, but what are your plans?
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
#27 |
Re: 1/2dozen Burban
Can't wait to see the progress!
My build thread for the bagged 91 http://67-72chevytrucks.com/vboard/s...d.php?t=654179 Build thread for the slammed 52 http://67-72chevytrucks.com/vboard/s...=1#post7683427 |
#28 |
Re: 1/2dozen Burban
Well it has been awhile since I've posted. Took some time but I was able to complete the garage with some help from my Dad. It was built to the max size the city will allow, which isn't big enough. Anyway, it's time to bag a suburban! Plans are to lay out using full level 3 porterbuilt drop members, 22 inch transport wheels with stock hub caps, having the 292 freshened up and 700r4. Here are some pictures and I'll be posting more as I go.
Full pic of shop ![]() At this point I was slowly raising the body to make sure everything was clear ![]() Body is off and frame rolled back ![]() Frame rolled back ready for fill dismantle ![]() Tucking the 22s purchased from Alexander Speed. Lift was lowered as far as the lift arms would let me ![]() 5 total wanted a spare ![]() Took frame down to the rails then power washed using a hotsy. Currently waiting on porterbuilt and in the meantime I'll coat the frame and clean up the mess I've made over the past few days. ![]() ![]()
66 suburban 51 Merc 2 door coupe 38 Chevy Business Coupe (gf's) 76 Airstream Sovereign |
#29 |
Re: 1/2dozen Burban
Nice suburban and shop!
Here in MI in most areas a garage cannot exceed the sq. ft. of the house. |
#30 |
Re: 1/2dozen Burban
It's gonna be awesome !
#31 |
Re: 1/2dozen Burban
Luckily we have a double lot so we could go max of 1200 sq. As long as it was connected. Otherwise, we could only use 30% of our back yard and peak of garage cannot exceed peak of house.
#32 |
![]() Join Date: Mar 2013
Re: 1/2dozen Burban
What's the plans for the 292? Maybe making it a street engine? Did it with mine. Great journey thus far. Nice project!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#33 |
Re: 1/2dozen Burban
I'm more of the cruising type. Plans are to freshen it up with new gaskets, valve seats and rings then paint it stock color. If it needs more when opened up then I'll go from there. It only has 48k on it and for the 3k I've driven it seems to get around pretty good. Just tired of the small seepage of oil making it all dirty! Your 292 looks great! What all have you done to it?
#34 |
Re: 1/2dozen Burban
A ton. lol Fully custom rebuild.
Lump port head...1.94 intake 1.60 exhaust valves. Roller rockers. Bigger valve springs, Bored .040 over with custom ross pistons, comp cam, fully balanced, zero decked. all the good stuff. lol ![]()
#35 |
Re: 1/2dozen Burban
Sounds like money! 4k or more? 350-400 hp?
#36 |
Re: 1/2dozen Burban
lol Not quite! The custom pistons make the compression at 9.5.1 and I didn't go to crazy on the cam..268 duration 218 @.050 .486 lift on a 110 lobe center. I'll be around 320 hp and 340 torque and $5000 perrty much covering it. Now if I went with 10.5.1 compression and a .550 lift cam I'd be seeing at around 350+ hp. lol
