![]() Join Date: Jan 2012
Do I need this?
This part sits in the water inlet by the thermostat with three tubes coming out of it. What is it? and Do I need it? (see black arrow)
Re: Do I need this?
Looks like a thermal vacuum switch for an EGR valve or some other emissions equipment that you likely don't need. Just unscrew it and plug the hole with an appropriate sized pipe plug.
Re: Do I need this?
Its something to do with vacuum and carb for heat reasons. Some kinda switch
Re: Do I need this?
not needed you may discard or sell as extra parts
Re: Do I need this?
Weird, what the heck is it for? Its over the thermostat so it doesn't see any action until the thermostat opens. Someone will know this site is loaded with knowledgeable people.
Toys/projects Many toys, not enough time to play! My youngest son and I picked up a 69 Chevy C-10 on 1/7/22, this is my second 69, it was 10 years ago that I had my other one. So I’m back!!! ![]() |
Junior Member
Re: Do I need this?
Just a guess, but looks like it may keep the vacuum advance from operating on the distributor until the engine is up to temperature.
Like said before remove it and plug the hole.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
