Removing glass with the stainless trim?
I see small signs of rust around the windshield and the rear window, so I want to remove them and sandblast the rust away.
I've pulled a rear window myself out of my 72 I had years ago and it was pretty easy. But the window didn't have the stainless trim around it. The trim is in very good condition and I don't want to damage it or bend it in any way. Any tips on removing this without having a glass guy come to the house? Same thing with the windshield, but I've never pulled one out before. Is it as simple as removing the stainless trim, and it pops out just like the rear window? I'm guessing the previous owner replaced the windshield recently, there are no pits or anything in it, it looks new. Thanks for any help Mark |
![]() Join Date: May 2012
Re: Removing glass with the stainless trim?
Remove the window with the trim still on.
I took a razor knife (from the inside)and cut around the window at the flange area put a blanket on the hood and pushed it out. no bubbles no troubles! cheers, Pat
#4 | |
![]() Posted via Mobile Device |
I just took mine out last week. I just used a utility knife with a sharp blade and cut rubber away. I did mine from the outside so i could push it outwards.
Active Member
![]() Join Date: Nov 2012
What Pat said. You can also get a squirt bottle with some soapy water to spray the gasket. It helps the razor blade cut easier.
67 C20 283/4 Speed |
![]() Join Date: Jan 2001
The rear window is tempered glass. You can start at one corner and push out from the inside while pulling the lip of the gasket over the pinchweld. Have a helper in the bed to catch the glass.
The windshield is a different matter. It's made of laminated glass, which cracks much more easily. In this case you have to decide whether to keep the glass or the rubber. The easiest way to get the glass out intact is to cut around the inside as others have said. There may be some windshield sealer between the outside of the gasket and the sheet metal, but it should be butyl sealer, which is pretty soft and should come apart easily. If you really want to save both the windshield and the gasket, and you're willing to assume some risk of breaking the windshield, the only way to remove it is to start at the bottom and work your way up. There is no way to remove a windshield from a 67-72 starting at the top without cracking the glass. The top corners are too sharply angled for that, but you may have success by going from the bottom. Installation is the reverse - start the windshield at the top, and work the bottom in. It's one of only two windshields I've ever done that need to be done that way. The other is the old Jeep Wagoneer. |
#8 | |
Thanks everyone for the idea's. I didn't even think to cut the gasket and just replace it, which I had planned on replacing anyways.
We'll see as the time gets closer, I may have the local glass guy come out for the installation. Thanks Mark |
Yes. One thing to consider. If you break the windshield,you bought it. If a glass installer breaks it,you bought it. If they break theirs,they go get another. Also,buying it from them the installation is in the price and usually hardly more than what you can buy one for. The key is to find a good glass shop. Late model windshields take far less skill than these,so do your homework and find someone who knows their stuff.
#10 | |
I like to use a hollow braid 3/16 nylon rope for installation. Lay it in the channel in the gasket starting at the center bottom (note this is different from most windshields) and bring it around to cross at the top. Have a couple of buddies help you hold the glass up in the opening with the gasket as far over the pinchweld as you can get it. Now pull the lip of the gasket over the pinchweld using the rope, being careful around the top corners. Having a glass guy help you may be a good idea, but as Special-K said, most of the guys in the business today weren't born when your truck was made, and most windshields have been glued in since the mid-70s, with urethane mandated for most installations by the 90s. Most of the current installers don't know much about gasketed installations, much less one as tricky as the 67-72 trucks. |
![]() Join Date: Mar 2012
I agree. Find someone who knows how to do these types of windshields, and get them installed so it wont leak. New ones just glue in place with no rubber. These are totally old school style. I got some prices around my area and my local GMC dealer was actually the best deal for new windshield and rubber installed. Plus they know how to do it.
#teamlongbed "I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb 1978 Chevy shop truck - static 6/8" 1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497 |
#12 | |
The main thing is finding someone who is familiar with these windshields and has done a number of them. It's definitely not the easiest one to learn on. |
![]() Join Date: Oct 2009
If you are going to do it yourself, do it just like Truckster said, but use plenty of soapy water to lubricate the seal.
I installed this kind of windshield in a GM plant many years ago, and if my memory serves, two men would do one every five minutes or so, so its' not hard once you get the hang of it.
1971 C10 Longbed, 350/TH350 |
I know of no way to remove them without breakage unless you cut the rubber first. usually the rubber is so hard and can't be used again anyway. Installing them like they said above is correct but would add dropping the seal in some hot water for 30 min before you start. And Dawn dish soap will be of great help with plenty of patience.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
#15 |
![]() Join Date: Jun 2011
Cutting it out is how I have always done it. It's going to be alot easier installing in a warm garage or on a hot sunny day. Doing it in cold weather can be done, but it's a pain.
#16 |
Thanks to everyone for the tips! I'll cut it out, order a new gasket and try my luck at installing it myself.
I'm getting the sandblaster and compressor this weekend, I'll probably start my frame off restoration in a couple weeks ![]() |
#17 |
Precision Restoration Parts has made a youtube video on removal and reinstalling these windows
