#101 | |
Re: Shawno72's long overdue 68 daily driver build thread
![]() Ill also see you at the swap meet this month you'll have to bring the truck down so we can set up a play date with all the guys trucks ![]() Posted via Mobile Device
![]() Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289 - Dylan (209)-985-7721 |
#102 |
C/10 junkie
Sounds good Dylan bu we will be in the wife's ride for Turlock.
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
#103 |
Dashing my hopes and dreams
![]() ![]() Posted via Mobile Device
#104 |
C/10 junkie
Got any pics of our trucks at Rene's? That was a very good play date
#105 |
I have a rolling shot from the cruise thru A t w a t e r and then a shot of the front of our trucks in the backyard ill have to see if I have more stashed somewhere
#106 | |
2016 RAM Laramie HEMI 1966 Fairlane GT/A, 390/335 HP If it costs you a dollar to make a friend, KEEP THE DOLLAR. If it costs you a friend to make a dollar, KEEP THE FRIEND. |
#107 |
Swing by and get me, Pops!
=MATTHEW 69 Stepper...Stroked & Bagged ![]() 2003 Chevrolet Z71 Ext. Cab 1995 Cavalier gas saver! |
#108 | |
C/10 junkie
#109 |
Shoooot, us Tennessee boys are at least smart enough to get off our mopeds when we have to take a leak!
#110 | |
C/10 junkie
#111 |
Here you go Shawn a couple I found of the C-10 Bash
#112 |
C/10 junkie
Nice!! Can't wait for the next caravan.
#113 |
I have a few others of the individual trucks back there wish I had gotten more. and no doubt I think this spring the group needs to roll down there and bust down Rene's back gate and make the backyard a little bit roomier for more trucks
#114 |
C/10 junkie
Yeah we will def have to put together a cruise to somewhere.
#115 |
My goals this year are Autorama this February Brothers in June Graffiti week (some pleasanton trip this year and Hot August nights. I'm tired of sitting around she's gonna travel far this year for sure!
#116 | |
C/10 junkie
#117 | |
#118 |
C/10 junkie
Haha I love it. Is the shwagin wagon on air?
Ok guys on another note. I am having a little problem. Last September or do I swapped out my one legged 3.73 gear set for a 3.07 posi. Well everything has been good since then but now once the rear end warms up a little I get a popping from the diff. I added 2 of the posi lube additives when I filled it after the install. I'm thinking about draining the fluid an just straight Lucas gear oil. It says on the bottle that you can use on posi units with no additive. What's your guys thoughts? Posted via Mobile Device
#119 |
Nice build
"The way it is" truck build http://67-72chevytrucks.com/vboard/s...d.php?t=359200 ![]() |
#120 | |
-Rus |
#121 |
C/10 junkie
#122 |
Shawn a friend of mine has a 72 with a 3:73 posi rear and he used straight Lucas gear oil in both of his differentials and he has no problems with his
Posted via Mobile Device |
#123 |
C/10 junkie
Thanks Rick, I've talked with some other people and they swear by the stuff so I think I'll give it a try.
#124 | |
![]() As far as the oil goes that should be fine for the rear end to run hopefully thatll get rid of the popping Posted via Mobile Device
#125 |
Shawno -
Does the popping happen all the time, when under load, at cruising speed or only when you turn corners? The reason I ask is that all the cars (and trucks) that I have owned with positraction clicked when turning. It wasn't really a pop, but more of a metallic click. Positractions are set up to "free wheel" when cornering to allow the opposite wheel to catch up. If both axles were "locked" it would bind the tires, causing excessive tire wear and put a lot of stress on the internals. Are you sure it's not a click... only when cornering? POP
