Old 01-07-2013, 03:51 PM   #1
1955GMC
LS engine centered and level?
I'm installing a LSx into a 55 GMC pick up with C-4 Corvette suspension front and rear. My using the Vette engine side brackets and donut style of insulators. My question is would it be alright if the engine went in at a slight downard tilt and 1 inch off center?
1955GMC is offline   Reply With Quote
Old 01-07-2013, 04:08 PM   #2
OldCreek
OldCreek's Avatar
Re: LS engine centered and level?
Downward tilt is probably o.k. depending on degree...
Drive lines degrees should not only be matched up/down but also left/right or some vibration will be had. Again, degrees matter. (I suppose you don't run a CV joint.)
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is online now   Reply With Quote
Old 01-07-2013, 04:59 PM   #3
1955GMC
Thanks for the quick reply. Well, in the old days we tried to keep everything level because of the carb floats. I was not sure if the unwritten law applied to the LS as well. This install would be much easier if I could leave the cab off.
Leon
Old 01-07-2013, 05:09 PM   #4
LEEVON
Moderator
LEEVON's Avatar
You want 3-6 degrees driveline angle.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 01-07-2013, 06:22 PM   #5
1955GMC
Thanks a lot. This information will be a real help.
Old 01-07-2013, 07:25 PM   #6
OKGMC4
OKGMC4's Avatar
When I did mine I made sure to make the C4 pumpkin match what the engine ended up with. I think I had 4 degrees down on trans and 4 degrees up on pinion. And on the off center part, mine is off about that much. Had to to clear the steering.
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Old 01-08-2013, 12:57 AM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
many ls engines look to sit a little "Crooked", although its an optical illusion. Mine does, but its not actually angled.
I run the engine 4* down.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
