12-28-2012, 12:32 AM | #1 |
I'm too scared to look!
Hi, everyone. Can somebody help me identify what I found in my oil pan?
I hope I attached the image correctly. I have a 71 gmc 454/400. Well, Im not sure if I have a 454 anymore after this tragedy...I got the oil pan off this morning and along with these two pieces there were many more smaller ones in there with it. also, after removing the intake I found a lot of metal scattered around the lifter valley...I am probably looking at a complete overhaul/rebuild yeah? Well, I got so bummed out about it that I couldn't bring myself to look up under the crank. I will tomorrow but until I do, can someone give me some advice??? Obviously, I am a novice so help is appreciated! |
12-28-2012, 12:35 AM | #2 |
Re: I'm too scared to look!
you may not be rebuilding anything u may be replacing... not to be a bad news person but thats not a good look to find this in ur oil pan
12-28-2012, 12:39 AM | #3 |
Is that chunkss of the crank??? Jeez man! Good luck!
12-28-2012, 12:42 AM | #4 |
i was hopeing
it wasnt pieces of piston or block Last edited by jc70chevy; 12-28-2012 at 12:43 AM. Reason: mis print |
12-28-2012, 12:46 AM | #5 |
Hard to say.. The right does kinda look like block and the right does kinda loook like a possible piston. Hope not though man
12-28-2012, 01:49 AM | #6 |
The right chunk looks like piston.....
Posted via Mobile Device |
12-28-2012, 01:54 AM | #7 |
12-28-2012, 02:24 AM | #8 |
both are piston.
left is piston pin area and the right is the lower skirt.. hopefully the rod didnt take out your block. but your in cali, so a bbc in the ole parts yard wont set you back much. plenty of cheap rebuilds in the last couple of years on super chevy/ popular hotrodding, google them, and for pretty cheap you can have a rebuilt bbc with around 500hp... |
12-28-2012, 02:34 AM | #9 |
yeesh thats scary looking right there, I can only imagine the amount of damage that was done to that block <cringe>
Hope for the best, brace yourself for the worst. Last edited by Xeen; 12-28-2012 at 02:52 AM. |
01-08-2013, 12:24 PM | #10 |
Thanks for all of your infinite wisdom and advice. I sure do appreciate it
