Old 01-07-2013, 10:40 PM   #1
bikeman59
B&M Unimatic Shifter - Install?
Has anyone installed one of these in a square. From what I understand, it is one of B&M's only shifters that mounts the activator parts below the floorboard. I'm not sure if there is enough room between the floor and the tranny to make this happen. According to the install info, it need 2.5 inches below the floor for clearance. Any thoughts?
Project: 1980 Chevy SWB
DD: 1999 Chevy Tahoe, lifted on 33"s
Toy: 1996 HD FLSTC, custom by me
bikeman59 is offline   Reply With Quote
Old 01-08-2013, 02:50 AM   #2
'79squared
'79squared's Avatar
Re: B&M Unimatic Shifter - Install?
Well I just did a B&M Mega style with no problems. Not sure what you mean by activator What kind of trans? Mines a 350. But the way it loops around the trans, I just put a slightly slotted whole for the cable to keep it a nice 45 degrees. I know with mine I actually had a lot of room under there.
1979 SWB 350/350
'79squared is offline   Reply With Quote
Old 01-08-2013, 09:51 AM   #3
77c10
77c10's Avatar
I think that shifter works like a Lokar. My truck had a Lokar in it when I bought it. The PO cut a HUGE hole in the trans tunnel to install it. That being said, it should work but don't hold my feet to the fire on that.
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint
"Cool ain't ever cheap and cheap ain't ever cool"
77c10 is offline   Reply With Quote
Old 01-08-2013, 11:52 AM   #4
bikeman59
Most of the B&M cable shifters only require you to put a big enough hole in the floor to pass the cable through, such as yours. With this Unimatic Shifter, you have to cut a hole about 1" x 3" for the base of the shifter mechanism to fit below the floor. According to the instructions, you need about 2.5 inches of clearance below the floor for this to fit.
Old 01-08-2013, 11:53 AM   #5
bikeman59
Ya, probably about the same. I've got the motor/trans out right now so I can't measure between the tranny and cab floor to see what type of clearence I have.
Old 01-08-2013, 01:22 PM   #6
77c10
77c10's Avatar
My Lokar had a plate that bolted to the top and back of the trans and that is what the shifter and linkage bolted to. No cable, just a piece of threaded rod with with small heim joints on either end.
Old 01-08-2013, 11:43 PM   #7
FritzA
I believe this shifter mounts to the driver side of the trans. That is where the shifter controls are on the TH400 and 700R. Similar to the side mounted shifters on muncie and saginaw manual transmissions.
You should have plenty of clearance imho.
FritzA is offline   Reply With Quote
Old 01-08-2013, 11:50 PM   #8
INSIDIOUS '86
INSIDIOUS '86's Avatar
I hate the clunky b&m shifters. Will only use their ratchet shifters for racing and that's after polishing and lube.
Mine has a lokar and I love it
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 01-09-2013, 11:34 AM   #9
bikeman59
OK, now you've got me curious about the Lokar. I'll have to look into that. Also, you mentioned polish/lube on the B&M. What are you polishing and lubing?
