Old 01-09-2013, 03:33 PM   #1
UATahoe
Patriot full length or clipster headers for 87 R10?
Trying to finalize which headers to use on my 87 R10. I am installing a new 383 and want to install headers at the same time. Truck is a 2wd and i will be keeping the TBI system. Truck is stock height right now and will remain that way. Main goal here is to keep the install easy and pick the set that will install without troubles. I will carry back from the headers with a new 2.5" true dual exhaust system. Anybody have pros or cons on the two options for headers mentioned? Thanks!
UATahoe is offline   Reply With Quote
Old 01-09-2013, 04:50 PM   #2
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Patriot full length or clipster headers for 87 R10?
Clipsters i had them on my 73. Got close on the bell housing ears.
Decent headers 5/16 flange. Not my 1st choice.
Looks at dougs D-310. Running them now. 3/8 flanges full length and tuck in the rail. But requires a diiferent trans x member because they tuck nicely.
Old 01-09-2013, 06:03 PM   #3
UATahoe
Was actually hoping to find something that didnt require modification. I guess i will look at other brands then. Sounds like there may not be a solution for a no modification fit.
Old 01-09-2013, 06:24 PM   #4
Damon23
Damon23's Avatar
I'll report back on how the hean elites go. I'm having them installed next week.
Damon23 is offline   Reply With Quote
Old 01-09-2013, 06:30 PM   #5
KQQL IT
At the body shop.
KQQL IT's Avatar
The dougs fit a double hump. Just not a single hump
Old 01-09-2013, 06:54 PM   #6
UATahoe
How do I find out what mine has? It is a 5.7 350 with the 700r4 transmission.
Old 01-09-2013, 07:20 PM   #7
INSIDIOUS '86
INSIDIOUS '86's Avatar
Hf trucks with factory true duall are the only doubl hump trucks
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 01-09-2013, 07:24 PM   #8
UATahoe
So no choices for headers that will fit without modification work?
Old 01-09-2013, 08:44 PM   #9
UATahoe
Also, how hard is it to modify the crossmember and where can you get the double hump replacement?
Old 01-09-2013, 10:19 PM   #10
INSIDIOUS '86
You can take to single humps and cut them in half an make a double from what I hear.
I have full length on mine with no mods. 3 in pipe with an s bend over the non him part. Not a big issue really I'm dropped quiete a bite so I tube over speedbumps and such.
Old 01-09-2013, 10:30 PM   #11
UATahoe
Oh ok. So I can just have the exhaust shop bend the pipe to make it work? That's a no brainer. I am stock height and will stay that way so it sounds like I will be fine. As long as the long tubes can work I will go that route and just work around the crossmember.
