ps gear box rebuild?'s
I have made my desicion too go with ps. I have a box that was in the kids truck it worked fine but it started leaking pretty bad out the input.(i know i couldve just replaced that seal but since i have the whole kit why not)
my kid bought a kit too rebuild the box but chickened out and just got another box from the yard. so here i am with two manual boxes and a leaky power box with the kit too choose from. I tore the leaky box down last nite and started cleaning and blasting the case.I figured i should have it ready to be assmebled tonite(maybe tommarow nite if i dont stay on track) anybody have any tips or secrets with assmembly? i watched a bunch of online vids and have a manual to refer too but outa curiousity wandering if anybody has any tips this is my first box i'm opening up oh and one last thing how many balls are in the box ![]() ![]() tips,tricks,secerts? and how many balls are there? thanks in advance on any info i recieve
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
Re: ps gear box rebuild?'s
http://www.pirate4x4.com/forum/gener...build-how.html
This is a very in-depth write up on it! Just don't worry about the parts where they are drilling and tapping holes for connecting a ram. Other that that, it's right-on. There are I believe 24 balls. 12 light and 12 dark. They are just barely discernable from each-other.
T.Y.N Custom Works..... Because "Stock" Sucks! 1971 K 10 GMC Long Bed 1977 Formula T/A Frame off Resto-Mod ![]() 1995 FXDL Harley Low Rider 1985 C10 ShortWide 91 Burb front. |
Active Member
![]() Join Date: Jul 2007
I did mine but last summer but the ball bearings on mine were all the same size and color. I was missing a couple but couldn't find them anywhere on the net or parts stores. I went ahead and reinstalled them like that and it works without any problems and no more leaks either.
Also, if you know of a place that sells these ball bearings post it here. I have another gearbox I would like to rebuild.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
![]() Join Date: Dec 2011
you can get the ball bearings thru ClassicParts.com p/n 76-875, it's on page 99 of they're 67-72 vol. 11 catalog as well.
1972 Cheyenne Super 10 SWB,bucket seats,dealer cruise,tilt,tac,a/c,shoulder belts, 350/350 1971 K-10 Custom Deluxe 1971 K-10 Custom |
Active Member
Thanks for ball bearing info. $42 seems somewhat steep for them though. I can get a used gearbox locally for around $40. I think that's what I will do.
oh wow! I didn't look at the price when I found the part number. ya I think you're right-get a good used one
well i finished cleaning the case then figured i scour around for the last three balls.... i guess the search will continue they may be small but they didnt leave the garage so keep searching
![]() the terrible part was is that i was ready for them too come out but i had the box resting on the vise and when i went too tip it so theyd come out the box slipped off the vise and...well you know the rest transformula thats a cool linkvery discriptive thanks 68gmsee i would be a lil' paranoid not havin all them balls in there with my luck the box would lock up while i was miles from home
I just watched a video last night on musclecar with the "red sled" project, after the red sled drive they rebuilt a ps box and made it look soooo easy. I will try to link it in a minute..
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
The balls are actually two different sizes as the black balls are spacers for the silver balls when they are new. There is probably no way to tell after it has a lot of miles on it though.
rick barely even got his hands dirty
![]() ![]() ![]() ![]() I new they didnt fall off the bench and roll to never never land but somehow one of them traveled quite far across the garage LET THE REBUILD COMMENCE! ![]()
Sweet, glad you found your balls
#15 |
ok all done.
over all i dont think it was too hard basicly you really just gotta pay attention too how everything comes apart and its oreintation. i kinda broke it down to each peice and made sure it was all clean and carefully removed each seal(in case one of the new ones broke) and replaced with the new ones the hardest thing i thought was trying too get the big rack piston back in with the new seal(it was binding)but some carefull screwdriver pushing and it went right in.just like the videos the bearings just get tapped in with the help of the correct sized socket I blasted and clear coated the case,top,end cap,pitman arm nut n lock washer and adjuster lock nut(i had this done the other nite allready) ![]() I ran a wire wheel around the openings of each bore of the case just too clean up some crud that was in there(also so everthing slided back in easyly) also did the stub shaft on the bench wire wheel i didnt wanna throw that in the blaster on account of where the seals ride gettin roughed up(i guess i coulda taped it up) I kinda liked the rotory valve thing it looks like where you put the bullets in a a revolver ![]() over all i think anybody with basic tools and some patience can redo a ps box. but i must say looking at the overhaul kit in the package with all those seals in it had me a lil' intimidated ![]() heres some pics
#16 |
Active Member
Great going!
I too found out it wasn't as hard as I thought it would be -but only after reading everything I could find about it. Mine was missing a couple of balls but since they just insure a smooth operation I didn't feel two less would affect the steering -which it didn't. Been driving it around for a year. If I do find additional ball bearings that don't cost an arm, I'll replace them.
#17 |
yhea i guess the hardest thing too do was find the bearings i dropped that took me more time and effort than anything
![]() but i guess the real test will come when i actually get the truck back together ![]()
#18 |
Cool, thanks for the pics and report. I like the blasted clear coat finish. very nice!
