Master cylinder threads
So swapping to power disks, McGaughy m/c. Easiest way to get rid of these threads? I'm not a small guy. It's tight under the dash to get in there to ditch the welds holding em in place.
Posted via Mobile Device Posted via Mobile Device
70 shortbed stepside "Schleprock" 350 w/TH400 rallys and BFGs -We can rebuild it, we have the technology-lower,shinier,faster |
Re: Master cylinder threads
Are you sure yours are welded? I was able to pop mine out using a dead blow hammer in my 67.
1967 SwB, 454 BB, 4L80E trans, 3.73 eaton posi 1997 C2500 Ext Cab 5.7 Liter 1955 3/4 ton 1st series w/ 235 straight six Sold it ![]() |
May be another 'gift' from my previous owner. He was terrible with a torch. Underneath the dash, where the base tightens up against the bracket, there are welds on all four studs.
![]() Join Date: Oct 2012
cut flush, with cut off wheel
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9 |
I hate to say it then, but your going to have to cut the welds and then pound them out to do it "right".
![]() Join Date: Apr 2012
Aren't these bolts used for the new setup?
Posted via Mobile Device |
The new power master cylinder has the threads coming from the booster, so the bolts will tighten from the firewall side.
![]() Join Date: Dec 2012
Did you get rid of the stand off bracket that has the pivot to raise the booster? I am not if you can do that can you? I am changing my booster tomorrow and am not sure if the 4 studs from the booster are even the same as the 4 sticking out of the firewall I am interested in seeing your set up
Thanks Posted via Mobile Device
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO ![]() |
I've seen pictures with the standoff bracket removed. The holes on the standoff don't align. I'll try to post up pictures.
