Ididit column for 47-54
Ive been looking at picking up an ididit column for my truck. Ididit's application specific column for my truck says its a 1" DD. From everything ive seen it looks most people use 3/4 DD. It will be connecting to the t-bird rack that came in my scotts ifs. As im sure you know itermediate shaft space isnt exactly plentiful on these trucks with a sbc. Anybody know what the deal with the 1" vs 3/4"s is?
Ididit part # 1120651020 is the one im looking at. It is no key and floor shift. Anything else to consider? Posted via Mobile Device
My Lost and Forgotten build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=442712 |
#2 | |
Re: Ididit column for 47-54
1.1 inch d/d x 3/4 d/d u-joint for the column 2.3/4 x 3/4 d/d u-joint for the frame 3.3/4 x 36 x 3/4 d/d u-joint for the power rack 4.3/4 d/d shaft for the steering 5.3/4 bung for the frame to secure the hime 6.3/4 hime 7.Ididit tilt steel column 8.Column drop 9.Floor mount I can help you out for sure on the above list of parts you will need for your truck.For the 1 inch d/d on the column this is what we have been installing in our shop for over 15 years. For Ididit this is the only column out there that comes with a lifetime warranty.This is the only column that is made in the USA 100%.This column also has 100% gm internal parts in the column. Justin |
![]() ![]() Join Date: Nov 2008
Now there's some customer service for you. You didn't even call them and they heard your needs & responded!
Posted via Mobile Device |
Awsome!
Justin takes care of his customers!
Justin nows his stuff and has some of the best customer support!!
Thanks Justin, I didnt realize the 1" to 3/4" universal is how it was done. Ill shoot you an email here in a bit.
Anybody know if the stock column drop will work with this column? The billety stuff doesnt really go with what ive got in mind.
The stock column drop will not work with the new ididit column.
We have our drop that is a tubular s.s column drop looks great take a look at it on our site www.scottshotrods.com |
What is the diameter of the column where the column drop bolts up?
Are the joints you supply borgeson?
[QUOTE=PurdueSD;5811413]What is the diameter of the column where the column drop bolts up?
Are the joints you supply borgeson?[/QUOTE Two inches dia One more thing you can do if you want something to be more in line with what you are building.You can take some 3/4 dia 120 wall tubing and tig weld these to your column and this will act as your drop and then you will need to weld on a mounting plate.You should use 3/16 plate and this will mount to your dash or the mount you will make to secure the column. Just a idea Justin |
The u-joints we sell
1.Uni-steer 2.Borgeanson |
