![]() Join Date: May 2007
Re: 4500 mockup begins-eng location ?
Got a pic of the engine and firewall.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
Made some good progress today. Got the high hump installed and set the cab back on to check fitment. Also bolted the T-case to the trans with the AA adapter. Bolted the 87 hydroboost steering box to the frame and some other small odds/ends.
The trans ended up almost perfect with the 3 1/4" move forward. |
Not the best photo. I'll get some better ones tomorrow with the distributer dropped in and from the side.
Looks like the stock trans shifter will hit the dash.
duallyjams-
Here you go. 3 inches between cap and firewall. |
I put the bench seat and shifter in yesterday to check for overall fit. It fits great! The angle on both axis' turned out to be spot on.
![]() The throw on the shifter on the 4500 is quite short. Guessing 6 inches max at the knob. The 3 1/4 move fwd turned out to be perfect. |
#8 | |
