Old 01-11-2013, 01:46 AM   #1
86c20
86c20's Avatar
85 colum to a 88 or newer streeing wheel
ok so i have a 85 with the thin wheel and the squarer horn and i got a 88 foam wheel with the small round horn butten but i dont think i have all the parts for it.
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
Old 01-11-2013, 02:07 AM   #2
Rubble
Re: 85 colum to a 88 or newer streeing wheel
I have swapped 4 or 5 of my squares to the 88 style wheels,If I remember all you need from the 88 is the wheel and button.You use the rest of the parts from your existing truck.The spring,plastic piece that holds the wire and wire itself.The 88 might have the same pieces too....hope this helps you....
1977 Chev C30 454/465/14ff DRW
1974 Chev C20.350/465/14ff
" Rock n Roll ain't noise pollution"
Rubble is offline   Reply With Quote
Old 01-11-2013, 02:14 AM   #3
86c20
86c20's Avatar
what spring and wire?? all i have is the cup on the 85 that is way to big to fit in the 88
Old 01-11-2013, 06:42 AM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
under the horn button
It's like a pen spring and wire for the contact
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 01-11-2013, 10:11 AM   #5
Rubble
Any way you can get a picture? The plastic piece goes on after the spring into a little tube.There is a notch in the tube that the plastic piece locks into to hold it in place. If your missing the tube,that might be why there's no other parts there.This tube is under the lock plate,there's a snap ring & spring that needs to come off to replace the tube.If I had one apart I would take some Picts for you...
Old 01-11-2013, 10:22 AM   #6
Rubble
I just looked on the LMC catalog,under steering components,it shows the lock plate & horn contact kit there.Maybe the wire was on the 88,cause it does show up here..Instead of the little button holding spring in place,there is this plastic piece & wire,the other end of the wire has a spade connector that plugs onto the inside of the horn cap.You might need a trip to the auto wrecker.
Old 01-11-2013, 12:01 PM   #7
86c20
86c20's Avatar
stad by for pics. will be the 85 wheel that is factory and the 88ish wheel i want
Old 01-11-2013, 12:55 PM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
this 88 coloum is out loose in the garage i can grab a pic after...
John
Old 01-11-2013, 04:16 PM   #9
86c20
86c20's Avatar
pics of what i have and what i want
Old 01-11-2013, 04:20 PM   #10
Rubble
Pull your wheel off,then you will see the spring set up I was telling you about.It will probably make more sense then eh....
Old 01-11-2013, 05:12 PM   #11
cory d
cory d's Avatar
i did the opposite on my truck. something with the horn switch didnt work. ended up just removing the horns, never used them anyways lol
cory d is offline   Reply With Quote
Old 01-11-2013, 07:59 PM   #12
Cherub
Cherub's Avatar
ive done this a few times and just use my existing hardware.
Cherub is offline   Reply With Quote
Old 01-11-2013, 10:47 PM   #13
86c20
86c20's Avatar
like a dumbass i forgot that my kids mother has a 89 berb with the same will i want so i took a look and now see what you mean about the spring wire and that is what i dont have. thanks for the help guys. later mike
Old 01-12-2013, 01:13 AM   #14
Rubble
Good deal,might mean a trip to the wrecker now eh...
