Old 10-30-2003, 02:59 AM   #1
72shadetree
KEEP ON TRUCKING
72shadetree's Avatar
Question what gear
on the 72 i got tore apart right now its a longbed will be running 402bb mildly built and not sure if im going run a th350 or a 400.it will be used some for pulling a 18ft car trailer.will be running 275/60/15 tires what gear ratio should i run i want to pull good but i dont want the rpm screaming at 70 mph.when i had the 350/350 in it it pulled real good with the 3.08.i was thinking about 3.73 or 3.42.it will see alot of highway use just looking for the best performance all way around.thanks
72 cheyenne 2wd lwb
71 k20 sons
bassett va
72shadetree is offline   Reply With Quote
Old 10-30-2003, 08:22 AM   #2
70c10
67-72 Addict!
70c10's Avatar
My 3:73's scream at around 3000 RPm on the highway with 275/60/15 on all four corners. . Not too bad in my opinion.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 10-30-2003, 08:39 AM   #3
VTKidder
I guess as a general rule, 3.73's are the perfect all around highway / town road / backwoods gears to have if you've got a tire size that's about standard. Personally, I've got 3.08's and 4.56's (night and day!) to choose from, and will probably go 3.08 as I do quite a bit of 50+mph driving. If I were to choose, and have a setup perfect for me, I'd go somewhere in between 3.73 and 3.08.
I haven't run the 3.08's on the interstate yet, but my goal is to be running around 2500-3000rpm at 80+ mph, whatever setup that gives me.
VTKidder is offline   Reply With Quote
Old 10-30-2003, 10:03 AM   #4
Woody
I would go with the 3.42 gears. The 3.73's are nice for towing, but 70 mph really turns the RPM plus how fast are you really going to drive it with out a trailer? 75-80? The 3.42 is a good gear , slightly better for highway milage, yet still low enough to pull decent, especially running a BB402. Just my 2 cents....
Woody is offline   Reply With Quote
Old 10-30-2003, 10:16 AM   #5
Huck
Huck's Avatar
I would run the 342 with a posi. Best of all worlds especially if you find a nice overdrive trans. It will give you the low end and the high end with lot of potential inbetween.
Huck is offline   Reply With Quote
Old 10-30-2003, 10:19 AM   #6
boraxman
Keepin an eye out
boraxman's Avatar
Another vote for 3.42, thats what I just put in my truck.
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 10-30-2003, 10:25 AM   #7
crazy longhorn
Fabricate till you "puke"
I would also go 3.42, your BB will have plenty of tork & the 3.42s will show you about 72mph @ 3000 rpms on the 275/60 /15 tires. Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 10-30-2003, 10:31 AM   #8
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
3:50 F@rd 9" Posi "The only way to FLY"
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 10-30-2003, 10:41 AM   #9
lukecp
Formerly yellow72custom
lukecp's Avatar
3.42 gets my vote too....that big block would still have enought toruqe for 3.08's to work good, but with a car trailer, 3.42's would be the way to go
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 10-30-2003, 12:06 PM   #10
72shadetree
KEEP ON TRUCKING
thanks i believe i will go 3.42
70cst ive been waiting for the truck to bring me that 9in
woody i dont drive fast much but i was clocked a couple years ago at 104 in a 70 in nc with trailer/drag car.we woke up late and its a 2hr drive to track had to get there
72 cheyenne 2wd lwb
71 k20 sons
bassett va
Old 10-31-2003, 12:06 PM   #11
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
And y'all said I was crazy!
Old 10-31-2003, 03:50 PM   #12
72shadetree
KEEP ON TRUCKING
had to get there hehe i wouldnt normally do that but the trailer is my cousins homemade i guess he got lucky and got the weight balanced right and my lwb with those hd leafs.it rides like a caddy loaded but will beat you to death when not i forget the trailer is there sometimes
72 cheyenne 2wd lwb
71 k20 sons
bassett va
Old 10-31-2003, 06:23 PM   #13
crazy longhorn
104 mph with a trailer & drag car? thats just cruisin ,why didnt you open it up! crazyL
Old 10-31-2003, 06:44 PM   #14
Not from our years, but My 96 has 3:42 and it pulls real strong (Vortec 350)...too much sometimes. Course mine has the OD...but when I had the 275/60 15 on it I would be doing about 2100 at 75. I had trouble that if it was even the slightest bit wet on the road, the rear would break loose unless you was a super old fart off the line.
Old 10-31-2003, 06:49 PM   #15
rage'nrat638
rage'nrat638's Avatar
th400 is one tough trans
rage'nrat638 is offline   Reply With Quote
Old 10-31-2003, 06:55 PM   #16
miket
miket's Avatar
Well I guess I am the odd guy out.....if you are building a big block with torque, I would say 3.08's are fine...the speed limits here are 60 and 70...I drive 10 over....at 60 my 502 is turning 2500....at 80 closer to 3200...thats gas guzzling RPM for any big block.
Comparitively speeking my Suburban with an OD and a 496 isn't far off....but it has 4.10's ...again with an OD.
FocuzTech Performance
Evergreen Protective Coatings
Gatorhyde...the best kept secret in spray in bed lining & protection
miket is offline   Reply With Quote
