connector C100 and C153 pin labeled "Ignition 3 Voltage??
does anybody know what this circuit does?
my harness is from a 2001 GMC 5.3 and it has brown wires called "ignition 3 voltage" according to wiring charts, one was in C100 pin n and other C153 pin c. traced wires out and it ends up on a small black 2 pin connector that i dont remember being hooked up. the other wire off the 2 pin connector seems to hook to a common ground splice. can i just delete this whole circuit?
My Projects- http://67-72chevytrucks.com/vboard/s...d.php?t=557301 Quest for Hot Rod Power Tour 2013. http://67-72chevytrucks.com/vboard/s...d.php?t=543735 my 85 GMC 2wd to 4wd conversion for the wife. |
meowMEOWmeowMEOW
Re: connector C100 and C153 pin labeled "Ignition 3 Voltage??
Front axle actuator circuit for turning 4wd on or something like that, at least per what the little pinout thing on lt1swap says. It doesn't say exactly, maybe a locker or something? All I gather is its for the 4wd, and not used.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() Last edited by BR3W CITY; 01-13-2013 at 02:53 AM. |
