01-13-2013, 11:25 AM | #1 |
frame dissassemble reassemble
So I am about disassemble my frame to send to sand blast gad a quick question. Wgen I go ti reassemble it would I use geade 8 blots on the ro
Rivied areas also. Posted via Mobile Device |
01-13-2013, 12:31 PM | #2 |
Re: frame dissassemble reassemble
do your self a huge favor and only pull the rivits you absolutly have too. you'll be ahead of the game if you do this and yes grade 8 bolts
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
01-13-2013, 12:45 PM | #3 |
Ok thanks. Why wouldn't you want to pull all of them. I understand it might be a pain when you go about putting it back together after either paint or powder coat
01-13-2013, 03:50 PM | #4 |
A better question, is why would you consider disassembling the frame? GM chose rivets over bolts because they WON'T come loose. Rivets are a better choice for a frame, and you don't gain anything by disassembling the frame IMO. Just have it blasted then clean and coat with your protective coating of choice.
01-13-2013, 04:26 PM | #5 |
True I just really wanted to make sure all the nooks and crainys were clean and clear of tge crap from tge last 40+ years of crud
01-13-2013, 04:27 PM | #6 |
But it does make more since with rivits and I don't have money to spend for the ritit gun press they use.
01-13-2013, 06:05 PM | #7 |
Here's mine after sandblast. It really gets into every nook and I don't think you should have a problem leaving it assembled. On the others hand I understand your concern and lmc sells a complete grade 8 bolt kit to replace all frame rivets
Scott 67 c10 sold 89 c1500 90 k2500 91 s10 #chevyonly |
