Old 01-14-2013, 07:02 PM   #1
canadian 4x4
canadian 4x4's Avatar
K10 spring hanger
what is the difference between the 4 wheel drive rear hanger and the 2 wheel drive ones? height difference? the forward rear spring hanger is rusted through on my k10. i have a c10 frame but its barried in a snow bank and i dont want to dig it out if they wont work
85 swb c10 6/6 drop
83 c10 bagged and sfbd project
canadian 4x4 is offline   Reply With Quote
Old 01-14-2013, 07:21 PM   #2
ray_mcavoy
Re: K10 spring hanger
Yes, they're different heights.
The 4x4 rear spring hangers (both the rearward & forward ones) extend farther down from the frame than the 2wd hangers.
ray_mcavoy is offline   Reply With Quote
Old 01-14-2013, 07:28 PM   #3
canadian 4x4
if i run the 2wd hangers, could i compensate by doing a shackle lift in the back to level it out?
85 swb c10 6/6 drop
Old 01-14-2013, 07:42 PM   #4
ray_mcavoy
Since the rear shackles run from the spring hanger up to the spring, I don't think it's even possible to do a shackle lift on these trucks.
You probably could compensate for the height difference in the 2wd spring hangers by using some lift blocks between the spring & axle. Or better yet, some higher arch lift springs.
Old 01-14-2013, 08:10 PM   #5
canadian 4x4
i don't wanna run blocks, and new spring arent in the budget at the moment but i might have to save some extra cash
85 swb c10 6/6 drop
Old 01-14-2013, 11:48 PM   #6
bdiamond
You could do a shackle flip to bring it back up.
bdiamond is offline   Reply With Quote
Old 01-15-2013, 01:26 AM   #7
Mr. 250r
Mr. 250r's Avatar
Why couldn't he do a shackle flip? but on the question a shackle flip raises the truck 4in so hopefully someone knows the difference between the 2wd and 4wd hangars because if they're say 2in different, is that 2in lift going to be worth it?
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 01-15-2013, 03:35 AM   #8
dieseldawg142
dieseldawg142's Avatar
ORD has 2.5 shackle flips
dieseldawg142 is offline   Reply With Quote
