Old 01-14-2013, 05:31 PM   #1
stepdog
Frames
Can anyone tell me if all 55-59 shortbox frames are interchangable GMC or Chevrolet.
stepdog is offline   Reply With Quote
Old 01-14-2013, 05:50 PM   #2
_Ogre
_Ogre's Avatar
Re: Frames
yes on chevy
motor mounts and core support might be different on the gmc
basically the same frame
shop air compressor timer
Old 01-14-2013, 07:20 PM   #3
OrrieG
OrrieG's Avatar
Re: Frames
58-59 the front rails are about 3" longer, but core support, spring shackles, etc. are all in the same location.
Old 01-14-2013, 07:24 PM   #4
stepdog
Re: Frames
So I should be able to use the 58 GMC frame in place of my 55 Chevy and just trim off 3 inches . Are the core support brackets the same?
Old 01-14-2013, 07:46 PM   #5
buggy5872
buggy5872's Avatar
Re: Frames
You should be able to use it. The front cross member is a little different also but that won't hold you up. Wait to cut the frame rails off until you mock up the front clip. That way you can set the bumper where you want it and do not risk cutting too much off.
___________________________
1959 Apache Short Fleetside,
1959 Apache NAPCO Long Stepside,
1957 3100 with 59 fleetside bed
1957 5700 LCF Crew Cab "Big Bertha",1959 GMC F370
1958 GMC 600, 1946 Chevy, 1959 Viking 60 LCF
1974 Elcamino SS, 1979 6500 GMC Tilt Bed Wrecker
Big Bertha Build
buggy5872 is offline   Reply With Quote
Old 01-14-2013, 09:00 PM   #6
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Frames
58 59 support brackets on the frame are different than 55-57 brackets.
Old 01-14-2013, 09:16 PM   #7
stepdog
Re: Frames
But I should be able to use the chevy core support brackets and remove the GMC. I dont know if there is a difference but the GMC frame is canadian. I think GMC used Pontiac engines and Canada used Chevy. I think?
Old 01-15-2013, 12:10 AM   #8
_Ogre
_Ogre's Avatar
Re: Frames
isn't the steering wheel on the right side in canada?
Old 01-15-2013, 11:01 AM   #9
stepdog
Re: Frames
Yea I guess I deserved that one.What I meant to say is the GMC frame is off a 58 9314 which is a canadian model. I think either GMC USA or GMC Canada used pontiac engines. I heard Pontiac engines were mounted different and that is why the GMC frame is longer than the Chevy.Or am I out to lunch on this one .Anyways I think the GMC frame will fit on my Chevy.
Old 01-15-2013, 12:36 PM   #10
mr48chev
mr48chev's Avatar
Re: Frames
The GMC six was/is a bit longer to begin with but I think the difference in frames between 55/57 and 58/59 has more to do with the sheet metal on the nose than engine size.
My ongoing truck projects:
mr48chev is online now   Reply With Quote
Old 01-15-2013, 01:50 PM   #11
OrrieG
OrrieG's Avatar
Re: Frames
Exactly, the hood and fenders are longer, engine crossmember is in the same place 55-59.
Old 01-16-2013, 01:26 AM   #12
G&R's57GMC
G&R's57GMC's Avatar
Re: Frames
On my '57 GMC the rad support mount is a center mount on its own crossmember. The trans cross member has a bolt in cross piece. The engine mounts are different then the Chevy also.
The pictures are of a Chevy frame that I'm using to replace the GMC Frame, note the rad support brackets on top of the frame rails. This will require a Chevy rad support and some mods made to the GMC grill to mount it.
I'm using a NoLimit Wide Ride front suspension system and their Fat Bar rear suspension and a Currie 9" rear axle.
G&R's57GMC is offline   Reply With Quote
