Old 01-15-2013, 01:04 PM   #1
PLANETGETLOW
1972 Chevy C10 - Heater Core
What's the simplest way to replace the heater core? Can you do it all from inside the cab?
PLANETGETLOW is offline   Reply With Quote
Old 01-15-2013, 01:12 PM   #2
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Re: 1972 Chevy C10 - Heater Core
If your truck has A/C you can, but if not, no you can't. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 01-15-2013, 01:14 PM   #3
Classic Heartbeat
Most people including myself drop the right front inner fender to gain access to all of the bolts to remove the housing containing the core. Some can do it without, but that requires more patients than I have most of the time.. WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 01-15-2013, 01:15 PM   #4
PLANETGETLOW
Yea, it's an AC truck.....What needs to come apart?
Old 01-15-2013, 01:15 PM   #5
PLANETGETLOW
I have the inner fender out...
Old 01-15-2013, 01:19 PM   #6
Roger71SWB
Roger71SWB's Avatar
Without A/C, I pulled mine by removing the R/H hood hinge first. other wise the blower motor doesnt have enough clearance to pull away from the fire wall. The hardest part is the bolt located just under the blower and above the fender. Get a new gasket set while you have it out. You can pickem up for under 20 bucks.
Roger71SWB is offline   Reply With Quote
Old 01-15-2013, 01:21 PM   #7
PLANETGETLOW
I haven't even looked at any of it yet but does the housing unbolt from inside the cab or in the engine bay? I'm getting mixed responses.
I was hoping that I could pull the housing from inside the cab and the heater-core will come out from there, with just the tubes pulling through the firewall.
Old 01-15-2013, 01:23 PM   #8
Roger71SWB
Roger71SWB's Avatar
Sorry i didnt see you that you had A/C.
Old 01-15-2013, 01:30 PM   #9
Classic Heartbeat
There are 4 bolts that pass through the firewall and the outer housing on an A/C Truck. You have to take those loose from the engine side. You also will have to remove the A/C duct selector from the inside. It is the one mounted to the heater core housing. Then unplug the wires to the high speed fan relay and the resister inside the housing. Then you should be able to pull it to change the core. A/C trucks are different than non A/C trucks. WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 01-15-2013, 01:36 PM   #10
PLANETGETLOW
Thanks dude, exactly what I was looking for
